Farmall Cub Disc Plow Holder
1 reply to this topic
#1 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted September 21, 2014 - 07:33 PM
So I needed to remount the rear lift arm to the Farmall Cub to use it to pull fence posts. Well, the belly disc plow either had to come off or a bracket needed to be made to hang it from the torque tube, being a factory option. Original was just a flat plate with two holes and a notch. Some I have seen others make are either built similar to OEM, or a flat plate with a grab hook welded on. I opted for a chunk of 2"x2" angle iron 3/8" thick that I had laying around. I still need to cut the top and bottom corners, and grind the grab part to make it easier to hook, but since I needed the tractor I roughed it out and bolted it on to try out. Works quite well.
Edited by wvbuzzmaster, September 21, 2014 - 07:35 PM.
  • Gtractor and Alc have said thanks
#2 Coventry Plumber ONLINE
Coventry Plumber
  • 1,087 Thanks
  • 589 posts
Posted September 21, 2014 - 07:44 PM
Looks great. Pays to save every piece of scrap steel.
