Sears Ss 15 Engine
4 replies to this topic
#1 silversolder429 OFFLINE
  • 1 Thanks
  • 2 posts
Posted September 21, 2014 - 05:14 PM
hey guys, new guy here . bought this tractor and seems to have a problem with the carb , it wont stay adjusted  .but i cant find any thing on the B&S engine to identify the model to find a repair kit . any help would be greatly appreciated .
  • Sawdust said thank you
#2 KennyP ONLINE
  • 39,165 Thanks
  • 46,325 posts
Posted September 21, 2014 - 06:04 PM
:wave: Welcome to the forum! There will be some folks along to offer help! Good looking tractor!
#3 superaben OFFLINE
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted September 21, 2014 - 08:48 PM
A repair kit is for the Briggs Flo-Jet Large 4 bolt.  The rebuild kit is $20 from me, part number 391071
The model number is stamped on the blower housing right behind the carburetor air horn.
Ben W.
#4 EricFromPa ONLINE
  • 3,821 Thanks
  • 3,170 posts
Posted September 21, 2014 - 09:14 PM
Yep those old Briggs carbs can be a bit stubborn.Most of the time they just need a good cleaning.The Main jet can be a bit of a bear to get out.I've had a bunch of them with messed up threads and stripped heads.
This video will help you to get it apart once you have it off the engine.
I Just rebuilt the Flo-Jet carb on an old 14hp.Once you get it rebuilt and cleaned up good they usually work very well for a few years.
On another note Those old carbs and engines don't like Ethanol.I've had problems with the main jet freezing up in the winter on alot of Flo-Jet carbs because of the water content in the cheaper E10 87 octane gas.I run 89 or better in everything now and haven't had a freeze up since.
#5 silversolder429 OFFLINE
  • 1 Thanks
  • 2 posts
Posted September 27, 2014 - 06:43 PM
thank you for the replies , i was gone for a week but will pull it and probably rebuild the carb .as far as the stamped number im afraid they must have painted over it , maybe they never heard of masking tape . LOL i appreciate the help , and im sure i will have more questions to follow .
