Good Small Fuse Block?
2 replies to this topic
#1 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted September 20, 2014 - 09:59 PM
My new Snapper has a bad fuse block. One fuse was held in by a small screwdriver jambing it in there to touch the contact. Yesterday I had Smoke issues on another fuse there. Might be problems elsewhere, yet I'm gonna start with a new block. This orig block holds the bigger push in fuses like cars used a few years back, some up to 30 amp. I'm thinking the same type or maybe even some with breakers instead of fuses???  This unit is about 4 to 5 INches long and hold four fuses, and bolts down at the feet on ends of plastic box. Is there generic type to look for at a generic type store, heh!  Not sure where to start. Guess could try search on epay, but not sure what to put in search. Maybe have to check hot rod catalogs??  Any suggestions?
#2 Jlaws OFFLINE
Jlaws
  • 556 Thanks
  • 368 posts
Posted September 20, 2014 - 11:45 PM
Grumpy , I put ......   4 gang fuse block ......in search for the ( Yard Garden & Outdoor ) section of ebay and came up with about 60 items . Mostly marine use but also some for automobiles ....Most looked like what your talking about .
#3 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted September 21, 2014 - 06:52 AM
  I've bought them at the local NAPA store.
                                            Mike
