Segmented Hydro Pump
6 replies to this topic
#1 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 19, 2014 - 02:21 PM
I have a 5 segment Hydro pump off a Jacobsen Greens King 4 that I cant seem to find any info on.
 I would love to know the pressure and flow rate of the segments for use on my Ingersoll 6018 loader backhoe(Dig-it 188T).
as it is now the 6018 has a 2 segment pump on it(one for drive motor,one for loader backhoe?)but I am wanting to add a 5ft hydro deck (quick connects /replace loader bucket)that is off a Jacobsen Turfcat 428d ..just wondering if the 5 segment pump would have the power...otherwise I will have to set up a belt driven pump and cooler just for the deck..Thanks in advance!
#2 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 19, 2014 - 02:48 PM
#3 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 19, 2014 - 03:24 PM
Pump is like this one http://www.ebay.com/...a9b56a8&vxp=mtr
#4 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted September 19, 2014 - 07:32 PM
Any chance you can find a service manual for a Greens King. That may give you more detailed info on the pump. It looks like some of the segments are different displacement than others. Not sure if you can directly combine the flows to increase volume without using check valves . I've never seen a multi segment pump like that.
#5 farmerall ONLINE
farmerall
  • 2,211 Thanks
  • 1,480 posts
Posted September 19, 2014 - 08:56 PM
Have you tried contacting Jacobsen? We have the manuals for these mowers where I work. I will see what I can find in them tomorrow.
#6 gopher OFFLINE
gopher
  • 768 Thanks
  • 760 posts
Posted September 20, 2014 - 07:25 PM
I wonder what kind of flow rate your 5ft hydro requires because Ingersoll sales 4ft hydracutters run from rear pto system?
#7 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted September 23, 2014 - 04:35 AM
Big question here; how many horsepower was turning that pump? And does your tractor have the ability to segregate the valve sections? If so AND you have the horsepower you could use a pump like that. What you could do is isolate individual circuits by pump section and thus have one of the slickest working machines around;-)
