kohler help asap please
23 replies to this topic
#1 M&M13 OFFLINE
M&M13
  • 11 Thanks
  • 159 posts
Posted February 14, 2011 - 11:06 AM
Posted Image kohler help asap please
A few wks ago i rebuilt a 10hp kohler motor its ran pretty good just needed carb adjusted ! guy was coming to pick it up so i pushed it outa the garage & was going to start & fine tune carb ! WOULDNT START!!! So that really put a knot in my plow line cuz i had to call him back & tell him it wasn't ready after all ! I checked the usual & nothing obvious ! As not to drag this out this is what Ive done over the last three days !! CHANGED : points 3 times, coil twice, condenser 3 times, adjusted valves 3 times to specs 1 time by site, 3 different carbs & 3 different plugs & it does the same thing every time valves in 00.9 exh 00.18 plug gap 30 points 20 ! Anyway symptoms are as follows
crank,crank,crank & nothin, pull plug no gas in chamber so i figure vacuum leak right cuz gas pours out carb when i choke it with my hand over it ! it will fire one time maybe a pop pop but no more than 3 & that's all your gonna get till i go through the whole song & dance again & then you might get it to do it again ! i can feel good compression leaking off real slowly when turning it by hand but that's normal right? i can hear carb sucking air on intake stroke also so anyway im stumped & need new set of eyes to go over this & tell me what I'm missing they all seem to run together after a while ! Posted Image
#2 MH81 OFFLINE
Posted February 14, 2011 - 11:39 AM
Sorry to hear about your luck, You've changed the electrical stuff, but do you have spark? If so, check that off, except for the plug... I don't see where you changed that. I also assume the wire that goes on the plug was changed.
I am running under the assumption that the leak off is compression release, but could it also be head gasket? What I know about Kohler engines could almost fill a thimble... I defer to the experts.
  • M&M13 said thank you
#3 M&M13 OFFLINE
M&M13
  • 11 Thanks
  • 159 posts
Posted February 14, 2011 - 11:48 AM
Sorry , yes plugs been changed got good fire all through wiring i tell you im stumped myself !
#4 101 senior ONLINE
101 senior
  • 239 Thanks
  • 372 posts
Posted February 14, 2011 - 11:51 AM
just a thought. Could gas tank cap vent be plugged? There is a stem that goes thru the carb that has the pick up hole for gas to go to the cyl. that gets plugged. check it.
  • 14,730 Thanks
  • 15,470 posts
Posted February 14, 2011 - 12:02 PM
Have you tried putting a little gas in spark plug hole? I might try that just to make sure your getting fire inside the cylinder
#6 M&M13 OFFLINE
M&M13
  • 11 Thanks
  • 159 posts
Posted February 14, 2011 - 12:12 PM
thanx caps not a problem but not sure wich hole you mean[attachment=7798:8520.attach]Also i know it does happen , but several carbs with the same problem at same time
#7 M&M13 OFFLINE
M&M13
  • 11 Thanks
  • 159 posts
Posted February 14, 2011 - 12:15 PM
thanx yep ! thats the only way i can get it to fire once ! its got to be air or fuel problem & something that is normaly overlooked or simple mistake ive made somewhere
#8 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted February 14, 2011 - 12:20 PM
Does the fuel pump push fuel out of hose good while cranking, unhooked from the carb?
#9 M&M13 OFFLINE
M&M13
  • 11 Thanks
  • 159 posts
Posted February 14, 2011 - 12:28 PM
well! it doesnt have a fuel pump its gravity fed ! Its getting plenty of fuel just out the wrong side of the carb
Thats it i bet ! i bet the earths gravity has changed & the goverment is just covering it up ?
CHECK THIS OUT TEXAS DEERE
http://www.outdoorod...nd-shoot-texas/
#10 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted February 14, 2011 - 12:49 PM
Is the exhaust valve going completely closed, I know you said you check clearence, but did you check to make sure that valve is closed all the way??
Those pictures on the hogs are from a site out of Turkey, not Texas, LOL
#11 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted February 14, 2011 - 02:40 PM
Does the plug have gas on it? Do you have enough gas in the tank?
#12 M&M13 OFFLINE
M&M13
  • 11 Thanks
  • 159 posts
Posted February 14, 2011 - 02:51 PM
YES ! valve is closing all the way ! i pulled head off again & checked everything one more time it fired up pop pop pop then died & thats all she wrote now its gotta kick back when i try to turn it over lol! I think its got a mind of its own 1
yeah i saw where they said it was in texas then turkey then saw where they were faked i may have sent you the wrong link
http://webcache.goog...=www.google.com
http://www.yourhoust...627cd259b0.html
Edited by APPALACHIAN EDGE, February 14, 2011 - 03:00 PM.
#13 M&M13 OFFLINE
M&M13
  • 11 Thanks
  • 159 posts
Posted February 14, 2011 - 02:54 PM
yep! gas in the tank although it wouldnt be the first time ive done that lol! plug not fouling aint getting enough gas to the chamber to foul !
#14 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted February 14, 2011 - 02:58 PM
I know this may sound stupid, but did you check for water in the gas ? You said it ran ,then you put it outside, and now it won't run. Could it be bad gas? I'm like you, IT SHOULD RUN .......:wallbanging::wallbanging::wallbanging:
#15 olcowhand ONLINE
  • 40,332 Thanks
  • 31,168 posts
Posted February 14, 2011 - 03:04 PM
You had the engine completely down? Are you SURE you got the timing marks aligned right on the cam/crank?
