Fuel Pump Rebuild Question
9 replies to this topic
#1 Busted wheel OFFLINE
Busted wheel
  • 17 Thanks
  • 16 posts
Posted September 17, 2014 - 10:04 AM
I just got a rebuild kit for the original cast iron fuel pump, and I am a little confused. Any direction would be appreciated.
In the picture below, my pump does not seem to have the screw labeled "Valve Plate Screw." It actually doesn't even have a corresponding hole where a screw would go. If there is no screw, what holds this in place?
Also, the second picture is a similar kit to what I bought, but what are the 2 things I circled in red?
I don't see anything in the original pump that are even close to similar?
#2 Busted wheel OFFLINE
Busted wheel
  • 17 Thanks
  • 16 posts
Posted September 17, 2014 - 10:24 AM
It could be possible the screw snapped off, but if it did, it was so clean that it is nearly impossible to see it. I am hoping this is not the case.
#3 JDBrian OFFLINE
  • 9,645 Thanks
  • 14,158 posts
Posted September 17, 2014 - 10:54 AM
I'm wondering if the extra parts are a replacement for the "valve retainer" in the picture or perhaps parts of that retainer that gets replaced. If there isn't a screw to hold it together it looks to me that the final assembly of the 2 halves using the "assembly screws" is what holds everything in place. It looks like it would be harder to assemble without the screw. Since I've never had one apart I don't have a good feel for how it goes together.
#4 Canawler OFFLINE
Canawler
  • 1,950 Thanks
  • 1,806 posts
Posted September 17, 2014 - 10:55 AM
There were two styles of check valves used depending on which specific pump you have and both are included in the pictured kit.  Since you don't have the style on the right I assume you have the discs on the left with the retaining plate.  If so, yes, there should be a screw holding the plate down.  As mentioned, maybe it broke off flush??
#5 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted September 17, 2014 - 11:03 AM
Can I ask where you found this kit? I have found kits with just the diaphragm, but not with the check valves.
#6 Busted wheel OFFLINE
Busted wheel
  • 17 Thanks
  • 16 posts
Posted September 17, 2014 - 11:46 AM
Ordered it form a place called "Then and Now Automotive" in Weymouth, Mass
http://www.maritimed...ohler_pumps.pdf
It's a real nice kit. Shipped to my door it was $33.
  • Bmerf said thank you
#7 Busted wheel OFFLINE
Busted wheel
  • 17 Thanks
  • 16 posts
Posted September 17, 2014 - 11:48 AM
Thats what I am thinking now as I can't see how else it would be held in place. I am going to try and carefully drill and tap it, but that is going to be dicey as the screw is probably harder than the surrounding metal. I really wanted to avoid putting one of the plastic pumps on, but it may come to that.
#8 Busted wheel OFFLINE
Busted wheel
  • 17 Thanks
  • 16 posts
Posted September 17, 2014 - 12:06 PM
SUCCESS! Now I just have to find another screw that would work.
#9 KC9KAS ONLINE
KC9KAS
  • 5,444 Thanks
  • 4,712 posts
Posted September 17, 2014 - 04:58 PM
I have heard war stories of these diaphragm not having the bolt holes made correctly.
Hope that problem has been taken care of.
#10 Busted wheel OFFLINE
Busted wheel
  • 17 Thanks
  • 16 posts
Posted September 22, 2014 - 12:00 PM
Mine lined up just fine. The whole process of rebuilding the pump is finicky to say the least, but tractor runs great.
  • KC9KAS and Rock farmer have said thanks
