Wisconsin s7d coil and flywheel install?
3 replies to this topic
#1 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted February 13, 2011 - 08:38 PM
I have a new magneto coil and flywheel to install in the Wisconsin s7d engine. Just like the Tecumseh's without a cutaway flywheel, how can I properly adjust the airgap of the coil and flywheel?
Any suggestions are greatly appricated. Thanks Adam
#2 Bolens 1000 ONLINE
  • 15,297 Thanks
  • 18,236 posts
Posted February 14, 2011 - 06:24 AM
I haven't worked with those mags in a while.... I think usually what I did was just eye it up.
Mabye Daniel will have some better advice for you
#3 olcowhand ONLINE
  • 42,434 Thanks
  • 31,812 posts
Posted February 14, 2011 - 09:20 AM
I trust my packing got the flywheel to you in good order? On the air gap, what I usually do is just slip the flywheel on, spin it, and if good hot spark I just leave it be, other than to make sure the coil mounting screws are tight. If I think air-gap is wide, or spark is weak, I loosen the coil just enough to where I can tap it in & out, slide it outward, then lightly slip on the flywheel. I slip the coil out till it hits the magnets, then in tiny increments, move the coil inward until it clears the magnets completely. There may be a more clinical method, but this is how I do it.
#4 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted February 14, 2011 - 08:08 PM
Dan, Thanks for the advice. Hopefully in the next few weeks I'll get around to putting it back together.
