Electric Clutch Help!
12 replies to this topic
#1 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 15, 2014 - 09:25 PM
I have a simplicity 4041 and I am trying to get the front clutch off of the crank to rebuild the motor and the front part comes off but the electric part of the clutch won't. any help would be great I am new to these. Thanks in advance
Tim
#2 KennyP OFFLINE
  • 38,478 Thanks
  • 45,969 posts
Posted September 16, 2014 - 06:09 AM
Make sure there isn't a set screw holding that on. Got any pics of it?
#3 farmer john OFFLINE
farmer john
  • 1,782 Thanks
  • 907 posts
Posted September 16, 2014 - 07:21 AM
i just had this issue, and after days of trying to remove it i finally gave up and cut it off with a mini grinder,
#4 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 16, 2014 - 10:25 AM
a can of 134a on the shaft will help,but I didnt recommend that ;)
#5 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 16, 2014 - 02:37 PM
Ok here is what I got
Tim
[attachment=127067:ImageUploadedByTapatalk1410896254.638041.jpg]
Edited by KennyP, September 17, 2014 - 05:11 AM.
#6 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 16, 2014 - 03:40 PM
Tim
#7 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 16, 2014 - 10:39 PM
Ok so there is your pic and a video now how do I get this thing off here
Tim
#8 KennyP OFFLINE
  • 38,478 Thanks
  • 45,969 posts
Posted September 17, 2014 - 05:16 AM
I can't get the pic to open. But the video works. How tight to the block is this?
#9 Alc OFFLINE
  • 6,905 Thanks
  • 7,468 posts
Posted September 17, 2014 - 05:25 AM
Tim I had the pto clutch off my 318 a few times but I didn't had any problems , I sure wish I could help what keeps that hub onto the shaft set screws at the keyway ? Heck I can't even remember how mine stays on :wallbanging:   Hope someone can help you
#10 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 17, 2014 - 04:56 PM
Ok I thought about it went out got my two jaw puller and some 1/4 inch by one inch plate steel welded it up to get get the crank gear off took it off. I guess seeing me do all that scared the clutch to death cause it just fell off when I walked to the other side of the block so I have it all taken apart. yeehaw !!!!
Tim
#11 KennyP OFFLINE
  • 38,478 Thanks
  • 45,969 posts
Posted September 17, 2014 - 05:31 PM
So the crank gear was holding it on there the whole time?
#12 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 17, 2014 - 07:49 PM
No the crank gear was on the other side I guess pulling it off freed it up and it slide off
Tim
#13 gopher OFFLINE
gopher
  • 764 Thanks
  • 758 posts
Posted September 17, 2014 - 10:31 PM
The next time your having trouble getting a bearing or something on a shaft off and have access to some of the shaft try dry ice. Go on line for vendor near you might be lucky one be close by. I had an old dodge 4x4 spindle bearing that would not budge my dad told me to try dry ice just so happens there is a Continental carbonic company in a city 20 miles away. They sale it in different forms from blocks to pellets. Not very expensive I think I paid $6 or $7 for 5 pounds of pellets. Make long story short took ice cream pail cut notch in side blocked up to spindle put the dry ice around it for a while hit the bearing with little butane torch and it came right off..
