John Deere 116
4 replies to this topic
#1 TheJunkKing OFFLINE
TheJunkKing
  • 32 Thanks
  • 18 posts
Posted September 15, 2014 - 05:30 PM
Hello -
I recently posted in the Ford section about the old Ford 120 I just got a couple days ago, along with several other pieces of equipment. You can see that thread here: http://gardentractor...n-old-ford-100/
Anyhow, as part of that haul, I also got a John Deere 116.
As you can see, it's a bit rough. But I figure I can get it running again. I'll probably get it in reasonable working order and then sell it.
Any comments, suggestions, observations, etc., are welcome.
Thanks!
#2 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted September 15, 2014 - 06:28 PM
Perhaps you have either the wrong hood or the wrong engine.  I have a 116 in the storage shed and it has the Briggs and Stratton vertical flat head opposed engine in it.  I checked on TractorData.com just to make sure.
Probably won't make much difference if you are just going to flip it though.
  • TheJunkKing said thank you
#3 TheJunkKing OFFLINE
TheJunkKing
  • 32 Thanks
  • 18 posts
Posted September 15, 2014 - 06:48 PM
Hmmm.... innarestin'. I'll hafta look at it a bit more closely. Mebbe someone replaced the engine at some point, or, as you say, it's not really a 116... curiouser and curiouser.
#4 nbent OFFLINE
nbent
    customizer
  • 652 Thanks
  • 532 posts
Posted September 15, 2014 - 11:15 PM
its had a motor swap the hood has the side panels bent for the brigs twin
#5 TheJunkKing OFFLINE
TheJunkKing
  • 32 Thanks
  • 18 posts
Posted September 16, 2014 - 01:55 PM
Yeah, after messing about with it for a few minutes, it's clear that's not the original engine. First, it has a pull start on top, that faces forward - under the hood. So it's a bit awkward to try to pull start it, because you have to pull the cord at an angle to avoid bashing your knuckles on the hood. Also, the choke knob and cable are gone, leaving just a hole in the dashboard, and this engine has an automatic choke, hooked to the governor, if I'm seeing the linkages correctly (which are a bit hard to see).
I got the engine to fire up a bit, using starting fluid, but it seems I need to open up the carb and clean it to get it to run right.
