My Horse Is Dead.
29 replies to this topic
#16 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted September 15, 2014 - 03:40 PM
Be nice to it, give it a sugar cube every once in a while.  Hope it is a easy fix.
Just don't feed it that cube through the gas tank!
  • rustyoldjunk and HANKG have said thanks
#17 DougT ONLINE
DougT
    Dog Approved
  • 7,079 Thanks
  • 5,063 posts
Posted September 15, 2014 - 04:16 PM
If you put the dead horse up on blocks in the front yard, you will qualify as a redneck amishman!   :smilewink:
  • rustyoldjunk, MH81 and Texas Deere and Horse have said thanks
#18 js5020 ONLINE
js5020
  • 700 Thanks
  • 798 posts
Posted September 16, 2014 - 06:53 PM
You could just board that horse up here in PA for the winter,,,, Ill get it running by spring for ya,, but Ill have to figure out a good excuse why it has the plow bracket marks on the axle when you come to pick it up :smilewink:
  • Texas Deere and Horse and HDWildBill have said thanks
#19 HDWildBill OFFLINE
  • 8,978 Thanks
Posted September 16, 2014 - 08:23 PM
That is probably his problem, it has been in the stable to long and when he took it out it didn't know how to act! :rolling:
  • rustyoldjunk, Texas Deere and Horse, KennyP and 1 other said thanks
#20 Texas Deere and Horse OFFLINE
  • 14,863 Thanks
  • 15,511 posts
Posted September 21, 2014 - 08:17 PM
I had time this weekend to work on the engine some and I found the muffler had moved down against the points cover and melted the screw out of the points set that the coil wire hooks up, I replaced the points, condenser and installed a new wire. While I was working on it I decided to pull the head to De-carbon the engine. I was amazed after 5 years of using on a almost weekly basis, it looks really clean to me. Has to be from using "Seafoam" in every tank of gas the Wheel Horse gets. The head has a little carbon on it, but it's not thick or flaking off.
Y'all take a look and let me know what you think..
IMG_20140921_184236_569.jpg IMG_20140921_184258_573.jpg IMG_20140921_184513_759.jpg IMG_20140921_184537_055.jpg
  • olcowhand, rustyoldjunk, KennyP and 2 others have said thanks
#21 MH81 OFFLINE
Posted September 21, 2014 - 08:32 PM
Almost clean enough to eat off Brian. I wouldn't loose any sleep over that little bit, but since its down, might as well clean it off.
Glad it was something simple on the repair.
  • rustyoldjunk and Texas Deere and Horse have said thanks
#22 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,962 Thanks
  • 1,074 posts
Posted September 21, 2014 - 08:33 PM
Looks pretty good, Brian. Guess I need to get some Seafoam. Glad it was easy, for once.
#23 Texas Deere and Horse OFFLINE
  • 14,863 Thanks
  • 15,511 posts
Posted September 21, 2014 - 08:43 PM
It has convinced me that the fuel treatment called "Seafoam" is a good product and does what it says. :thumbs: I will continue to use it in everything I own !!
  • rustyoldjunk, MH81, KennyP and 1 other said thanks
#24 olcowhand ONLINE
  • 42,452 Thanks
  • 31,823 posts
Posted September 21, 2014 - 08:56 PM
Glad something has finally turned out good for you Brian.   :thumbs:
#25 KennyP ONLINE
  • 40,187 Thanks
  • 46,794 posts
Posted September 22, 2014 - 05:10 AM
Glad you found the issue with the engine! That looks pretty good in there. I use Seafoam a lot too.
  • rustyoldjunk said thank you
#26 Texas Deere and Horse OFFLINE
  • 14,863 Thanks
  • 15,511 posts
Posted September 28, 2014 - 07:38 PM
I finally had time to work on the engine this morning so I could mow this afternoon. Got everything cleaned up and back together and torqued down. Still didn't want to run and was just acting like it was firing every few revolutions. I pulled the points cover and realized that I hadn't replaced the points, just fixed the wire. I went ahead and changed the points and it fired right off. Adjusted the high idle jet and it's running better then it has in quite a while. I also found that it must have been rebuilt shortly before I bought it over 10 years ago as it has a .010" over sized piston in it and it's good and tight in the bore.
IMG_20140928_124118_281.jpg IMG_20140928_124122_544.jpg IMG_20140928_124134_629.jpg
  • olcowhand, rustyoldjunk, DougT and 5 others have said thanks
#27 Bill56 OFFLINE
  • 842 Thanks
  • 2,179 posts
Posted September 28, 2014 - 09:11 PM
Good to hear your repairs are going well, Brian!
#28 HDWildBill OFFLINE
  • 8,978 Thanks
Posted September 28, 2014 - 09:21 PM
Glad to see you were able to get the horse back up on it's feet and running.  It's not good for a horse to be down.  :smilewink:
#29 KennyP ONLINE
  • 40,187 Thanks
  • 46,794 posts
Posted September 29, 2014 - 06:27 AM
Glad you found the right 'perscription' to get the horse back on it's feet and going again!
#30 olcowhand ONLINE
  • 42,452 Thanks
  • 31,823 posts
Posted September 29, 2014 - 07:42 AM
No breakdown is good, but shop time is good therapy, especially when things go well as in this case.
  • Texas Deere and Horse and SupplySergeant have said thanks
