I came across some hydraulic pumps
9 replies to this topic
#1 nra1ifer OFFLINE
nra1ifer
  • 674 Thanks
  • 1,531 posts
Posted February 13, 2011 - 04:03 PM
I came across 4 used hydraulic pumps. Not sure what to do with them yet, but here's a link to a description of them:
Parker - H39AA2C
From the specs, it looks like they'll be good to put on the shelf to use for something!
#2 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted February 13, 2011 - 07:00 PM
It doesn't mention the displacement. With out that it's hard to know how well the pump will work for your application.
#3 nra1ifer OFFLINE
nra1ifer
  • 674 Thanks
  • 1,531 posts
Posted February 13, 2011 - 10:27 PM
A document I found says 3.93 GPM per 1000 rpm.
At the moment, the only thing I could even imagine building would be a log splitter. I'd need to do some research to see what pump capacity that would take. Any idea?
#4 olcowhand ONLINE
  • 41,092 Thanks
  • 31,402 posts
Posted February 14, 2011 - 03:07 PM
That pump would work great for a front end loader on a garden tractor. You'd want to pulley it for around 8gpm, or 2,000rpm max.
#5 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted February 14, 2011 - 04:16 PM
Dan
Do you think the sleeve bearing will handle the side pull of the belt?
#6 olcowhand ONLINE
  • 41,092 Thanks
  • 31,402 posts
Posted February 14, 2011 - 06:06 PM
Dan
The one I've been using a few years now on my FEL is sleeved and still going strong. I am using a 5/8" belt & don't have to have it very tight though.
#7 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted February 14, 2011 - 09:18 PM
Ok, in that case it might be just what i need for my tractor project.
#8 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted February 15, 2011 - 12:15 PM
That's great to here.
Now I can use one of the many pumps I've collected over the years.
#9 olcowhand ONLINE
  • 41,092 Thanks
  • 31,402 posts
Posted February 15, 2011 - 04:11 PM
And if the pump shaft is long enough, or you can add a shaft extension, then you could add a pillar block bearing out there for even more security. I just run my belt barely snug. It will almost slip under a heavy load, but no high side load on the shaft this way.
#10 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted February 15, 2011 - 07:21 PM
I never even thought about side loads on a pump but I think if it was concern maybe a double pulley or how about a belt tensioner that's close to the pump pulley so more of the belt makes surface contact with the pump pulley .
