Yep It's Fatal
26 replies to this topic
#16 68guns OFFLINE
68guns
  • 124 Thanks
  • 80 posts
Posted September 15, 2014 - 06:44 AM
Can anyone shed some light on why this would happen? Granted, the tractor was built in 1973. The trans fluid was at the proper level and I had just completed the axle adjustment an hour before. Plus I was mowing on level ground so not a lot of load there.
  • MyBolens1053 said thank you
#17 Deerlope OFFLINE
Deerlope
  • 819 Thanks
  • 483 posts
Posted September 15, 2014 - 07:18 AM
Not fatal just a bump in the road. We wear out and so does metal. Maybe a flaw in the machining of it or the heat treating process. I would call it metal fatigue. Think of how many RPM's that has made since 1973.
#18 68guns OFFLINE
68guns
  • 124 Thanks
  • 80 posts
Posted September 15, 2014 - 07:34 AM
http://akroncanton.c...4591198700.html. I found this one in the area. Looks like its in decent shape but maybe some trans probs as well??? What do you think?
#19 farmerall OFFLINE
farmerall
  • 2260 Thanks
  • 1495 posts
Posted September 15, 2014 - 11:41 AM
That looks like a nice tractor. It sounds like a gear is stripped in the trans though which is a common issue for the 6 speed transmissions.
#20 nglauer OFFLINE
nglauer
  • 458 Thanks
  • 379 posts
Posted September 15, 2014 - 02:35 PM
There is one just outside of Cambridge Ohio ... off I-77. http://zanesville.cr...4576999879.html Where are you traveling from?
#21 nglauer OFFLINE
nglauer
  • 458 Thanks
  • 379 posts
Posted September 15, 2014 - 02:40 PM
I suppose this one could be closer. It's a 1050 without a motor - http://youngstown.cr...4666111469.html
#22 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted September 15, 2014 - 03:07 PM
The 1050 is a 6 speed guys, he needs a 3 speed.
These do break from time to time but not that often. Over tightening and not following maintenance on rear axle end play could be the culprit as well. Its 41 years old, thats alot of time to be abused/neglected.
#23 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted September 15, 2014 - 03:46 PM
I have a used trans I dont know what the guts look like but I will make you a deal on it......
  • Bolens 1000, 68guns and MyBolens1053 have said thanks
#24 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted September 15, 2014 - 04:13 PM
Check your PMs.
#25 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted September 18, 2014 - 11:52 AM
Too bad you were not close to NH. Seems like there are always some gear driven Bolens around for parts. I sure hope you find one. I think you are best off getting a parts tractor with a good tranny then you have some spare parts.
#26 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted September 18, 2014 - 06:33 PM
He's found a tractor :D :D :D
  • KennyP and MyBolens1053 have said thanks
#27 68guns OFFLINE
68guns
  • 124 Thanks
  • 80 posts
Posted September 18, 2014 - 08:15 PM
Thanks to my fellow Buckeye, Old Buzz hooked me up with runout G10! Huge thank you to you Buzz. Sure does pay to be a member of this forum. Thanks also to all the guys who contacted me with ideas and suggestions.
Edited by 68guns, September 18, 2014 - 08:26 PM.
  • olcowhand, KennyP and MyBolens1053 have said thanks
