Yep It's Fatal
26 replies to this topic
#1 68guns OFFLINE
68guns
  • 124 Thanks
  • 80 posts
Posted September 14, 2014 - 07:19 PM
I was out mowing with G10 today when all of the sudden...it wouldn't move anymore! Smelled like burned transmission. Checked the level it was at the correct level. Pulled it apart and here is what I foundfatal.jpg Sheared in half.Man I really loved that tractor. Weighing my options on what to do next.
Edited by 68guns, September 14, 2014 - 07:22 PM.
  • Alc, blackjackjakexxix and MyBolens1053 have said thanks
#2 farmerall OFFLINE
farmerall
  • 2260 Thanks
  • 1495 posts
Posted September 14, 2014 - 07:24 PM
Ouch. Looks like it's time to swap in a 1050 trans.
  • MyBolens1053 said thank you
#3 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted September 14, 2014 - 07:25 PM
Dont Panic!
Plenty of 3 speed transmissions and parts tractors out there, grab another 3 speed tranny and keep this one for parts. Can be up and running in a few hours :thumbs:
  • olcowhand, Alc, Texas Deere and Horse and 2 others have said thanks
#4 JDBrian OFFLINE
  • 9682 Thanks
  • 14162 posts
Posted September 14, 2014 - 07:27 PM
If you loved that tractor then get a line on a good used tranny and bring it back to life. Another G10 would never be the same!
#5 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted September 14, 2014 - 07:28 PM
Not fatal....just needs a little intensive care, then she'll be out of the hospital in no time!
#6 bread320i OFFLINE
bread320i
  • 614 Thanks
  • 1225 posts
Posted September 14, 2014 - 07:54 PM
Not to worry. These trans are very common and replacement should not be that hard, If you are looking for a cheap fix, watch craiglist. If you need it fixed asap I am sure a member has what you need.
#7 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5122 Thanks
  • 2911 posts
Posted September 14, 2014 - 07:57 PM
If you don't want to replace the whole trans, you can buy a used axle, but that will cost almost the same as a whole trans.
#8 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Posted September 14, 2014 - 08:46 PM
What transmission did Bolens use?
I might be even able to get that piece new.
Ben W.
#9 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted September 14, 2014 - 08:48 PM
Shucks, that ain't fatal. Like others have said, that's fixable, and you have a number of options.
Get the parts to fix it, find another 3-speed transmission, or even replace the whole rear end with one of the 6-speed rear ends.
If you replace the whole rear end with one from say a 1050, you will get the controlled differential that the G9, 10, and 11 lacked, and the added 'advantage' of having 12-speeds so you can do this :D :D :D
https://www.youtube....h?v=a6xbaP1DH6E
Edited by OldBuzzard, September 14, 2014 - 08:55 PM.
#10 68guns OFFLINE
68guns
  • 124 Thanks
  • 80 posts
Posted September 14, 2014 - 09:05 PM
Which transmission swap would be easier a 1050 or 850? This is virgin territory for me.
#11 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted September 14, 2014 - 10:07 PM
Or would you like a used G10 trans?
#12 68guns OFFLINE
68guns
  • 124 Thanks
  • 80 posts
Posted September 14, 2014 - 10:16 PM
Prefer G10..all depends on difficulty and price.
#13 MyBolens1053 OFFLINE
MyBolens1053
  • 689 Thanks
  • 602 posts
  • Location: Martinsburg, WV (surrounded by Apple Orchards)
Posted September 14, 2014 - 11:53 PM
We see you were able to open and identify the problem so you have the skills to swap a trans-axle unit out. I wanna say I saw on CL a trans for a 1050 with wheels for $125.00, possibly around Pittsburgh, PA.
Good luck.
Edited by MyBolens1053, September 14, 2014 - 11:54 PM.
#14 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted September 15, 2014 - 04:41 AM
Ben W.
That would be pretty hard to do,Bolens built their own Transmissions.
G10's are a dime a dozen and you should have no problem finding one to keep it original.
Part number your looking for is 1722140
  • superaben and MyBolens1053 have said thanks
#15 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted September 15, 2014 - 06:36 AM
Sorry to hear about that but like the guys say you certainly get it back up and running for not a lot of money.
