Hot Running Ht20
18 replies to this topic
#16 fogler12538 OFFLINE
fogler12538
  • 284 Thanks
  • 170 posts
Posted September 16, 2014 - 03:56 PM
Got it running good jumped on it to test drive it and it wouldnt move ahead or backward, also the the lift arm wasn't working. Change the fluid and filter in rear end? I drove it yesterday around the yard and it seemed to go well.
#17 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted September 16, 2014 - 04:49 PM
Thanks Brian. My other question to anyone who can answer is. What is the right way to fine tune the idle adjustment screw (the short one). It didn't seem to have any effect when I turned it in or out. Thanks Jim
Its funny, every engine is different, some take alot of adjustments past factory settings and others are right on the initial specs.
Glad to hear you got it running.
  • fogler12538 said thank you
#18 Rock farmer OFFLINE
Rock farmer
  • 1537 Thanks
  • 1434 posts
Posted September 16, 2014 - 06:40 PM
Do you have any hydro leaks?
I'd check fluid level first. If that's OK, then check the drive shaft for a broken key. Front or rear.
Joe
#19 fogler12538 OFFLINE
fogler12538
  • 284 Thanks
  • 170 posts
Posted September 19, 2014 - 07:50 PM
Got the HT20 moving again, the filter was plugged but now it's running terrible again. On well I'll get it sooner or later
  • Bolens 1000 said thank you
