Kohler Carb Surging When Throttled Up .
36 replies to this topic
#16 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 14, 2014 - 02:09 PM
You will still need the gasket for the elbow and the carb to intake(I always make my own)
  • alec said thank you
#17 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 14, 2014 - 02:11 PM
the screw on the side is for low Idle mixture,and the screw on top is for high mixture.
  • Alc and alec have said thanks
#18 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted September 14, 2014 - 02:19 PM
thanks man !
  • Auburn David said thank you
#19 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,293 Thanks
  • 9,776 posts
Posted September 14, 2014 - 03:14 PM
As dirty as it is, I would suggest soaking the carb in a bucket of carb dip cleaner. Spraying cleaner around here and there doesn't really do it.
#20 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted September 14, 2014 - 04:00 PM
I bought a gallon of carb soak cleaner with a basket in it from NAPA. It isn't as strong as the old stuff I used 30-40 years ago, but it works!
#21 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted September 14, 2014 - 05:39 PM
I had good luck with the b212 and the 7117 ( with a sovereign transplant ) when I drained the gas out of the lines and needle seat . I figured this one would do the same as my pushmower so I was looking for the little hole in the bottom bowl nut ( couldnt find one  ) and the cup gasket is crappy . so I will go ahead and drain and clean the tank and lines ,change the filter and soak the carb and do the basic rebuild . how does a guy flush the fuel pump ?
#22 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted September 14, 2014 - 05:42 PM
nothing is as good as the old stuff .....its really a shame I had to start making my own laundry soap because the new stuff is crap . :offtopic: (it works great )
#23 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted September 14, 2014 - 08:48 PM
If you have a k301 and it is running great until up above half throttle, where it begins surging, then do me a favor. Look in the bore of the carb for a number, it should be 26, and if you have a 30, it will perform as you are experiencing. Trust me, just made this mistake recently.
#24 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted September 14, 2014 - 08:53 PM
I will check tomorrow when I get to the farm . would I need to replace the carb or what ? ( if it was a 30 ) or is there a fix ?
#25 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted September 14, 2014 - 08:58 PM
The only fix is to replace with a 26 carb. The 30 has so much air flow capability that can not be overcome in the smaller engine. The 30 is designed for 14 to 16 hp. I know that sounds close enough, but believe me, it is not. The bore diameter is in millimeters and a 26 carb is roughly 26 mm or 1 inch, and a 30 carb is 30 mm, a lot bigger bore, but the outside dimensions are the same as the 26.
#26 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted September 14, 2014 - 09:01 PM
Oh, if you need help getting a 26 carb together let me know, I have some parts I have been mixing and matching because someone took the plates out.... Of around 4 carbs...
Edited by wvbuzzmaster, September 14, 2014 - 09:01 PM.
#27 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted September 14, 2014 - 09:46 PM
I will know tomorrow and will get back to you . how much for a 26? and what plates are we talking about ? just curious
#28 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted September 14, 2014 - 10:09 PM
Throttle and choke plates were removed so thse shafts woud come out.... And I dunno why he did that, but I didn't know that since it was sight unseen. Oh, he also kept the flats out of them.... I might try to get some small screws, reinstall the plates, and smash the screws to keep them in. I would not charge three arms or one leg. I would sell for around 30 dollars, with no float or gaskets, so you would need the basic kit still, but you can use your old float, needle, and gaskets if you want. I did that last week and it was ok.
Edited by wvbuzzmaster, September 14, 2014 - 10:09 PM.
#29 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted September 14, 2014 - 11:00 PM
thanks I will keep in touch . will find out tomorrow
  • wvbuzzmaster said thank you
#30 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted September 15, 2014 - 07:19 PM
checked the carb ,it is a 26 so I ordered a kit and will soak it tommorow and put it together the next day ,
