Hydraulics To Run A Splitter - Cub Cadet, John Deere, Case
16 replies to this topic
  • 565 Thanks
  • 507 posts
Posted September 17, 2014 - 11:51 PM
Tudor, can you give more information about this one??Like the Aux pump and such??
The pump has a displacement of approximately 0.39 cu-in, sized for the loader. It's a bit small for the splitter, but it does the job. The one on there now (replaced in '96) has a 5/8" shaft which seems to be hard to find in the new pumps. The 1/2" shaft twisted off on the old pump.
At 1500 psi, the 3.5" cylinder has 7 tons of push. That's been enough to split about 98% of the maple, birch, and beech logs that I've dealt with. An 8 lb maul and a 12 lb sledge can deal with the rest, if I'm feeling ambitious.
If you want more speed, you need more pump dispacement. If you want more force, either a higher relief valve setting or a larger diameter cylinder is required.
My setup has a Cross 10 micron filter in front of the pump and the valve set is permanent to the tractor. The splitter has the cylinder and the 2 hoses with quick connects to join to hoses from the valve set. The reservoirs are the loader's posts, about a gallon of Dexron ATF each. Work lines are 1/4" hose and the pump supply and reservoir crossover hoses are 3/4". A bigger pump will require bigger lines.
This was one of my first hydraulics projects and is missing the system relief valve that should be right after the pump. With the location of the loader and auxilliary valve sets being at some remove from each other, it's difficult to operate both under load at the same time and there is little risk to destroying the pump. That oversight will be corrected when I refurbish the tractor which has been parked for several years.
  • MH81, Alc and TomLGT195 have said thanks
#17 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted September 18, 2014 - 06:18 AM
Use your Case tractor it will run the splitter the best by far!! And engine oil is fine for the splitter cylinder. All you need is the aux. Valve kit for it. ( the one to run rear pto attachments) and your golden! It will be as fast and as powerful as most store bought units and attached to your tractor so the neighbor won't want to borrow it.
The pump is direct drive and capable of making at least 2500 psi with ease. A belt driven unit is just more to maintain and not going to produce very good speed or power.
  • motobreeder and TomLGT195 have said thanks
