Wire Harness Cub Original
9 replies to this topic
#1 bryan 110 OFFLINE
bryan 110
  • 222 Thanks
  • 293 posts
Posted September 12, 2014 - 07:47 PM
Looking for a wire harness for a cub original it's a 61 and I would like to get it cheee--eeeeep if possible.and a points cover. So I don't start on fire again.
#2 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted September 12, 2014 - 08:05 PM
Points cover I can help you with, brand new from Kohler.
A wiring harness is available off eBay if you know your serial number.  http://www.ebay.com/...5778524?lpid=82
Ben W.
#3 zippy1 OFFLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted September 12, 2014 - 11:00 PM
There isn't much for wires on a original, easy enough to make your own.
I didn't check prices, I just made my own.
If you have any of the original one left, it would be a breeze.
  • WNYTractorTinkerer and superaben have said thanks
#4 bryan 110 OFFLINE
bryan 110
  • 222 Thanks
  • 293 posts
Posted September 13, 2014 - 09:49 AM
I was thinking about doing that but thought it would be easy to just unbolt and bolt a new one on. Not to worried about it because I'm not going to start redoing it till the winter anyways. Just thought it would be nice to have the parts on hand I guess. And my cub is a 1961 so the ebay one won't work..
Thanks for the reply guys
#5 IHCubGuy OFFLINE
IHCubGuy
  • 1,611 Thanks
  • 1,638 posts
Posted September 13, 2014 - 10:48 AM
Try this one instead then.  It's from the same vendor.
http://www.ebay.com/...=p2054897.l5658
Personally though I am really racking my brain to figure out what the difference is between them.  The only thing I can think is that the one is for a pull start and the other is for an electric start.  But this would not have a bearing on the serial number as they were offered both ways all through production.  We have a 4 digit 1st month production Original and we have a 63 model one as well and I cannot for the life of me think of the difference between the harnesses.  Both of them are electric start as well.  I know our 63 model pull start is different as it only has wiring for the kill switch and nothing for the starter/generator, voltage regulator or push button start switch.  They are at the farm and I am too busy today to go check the differences out.  I may need to check this out further to see what I am missing here.
Edited by IHCubGuy, September 13, 2014 - 12:36 PM.
  • superaben said thank you
#6 bryan 110 OFFLINE
bryan 110
  • 222 Thanks
  • 293 posts
Posted September 13, 2014 - 12:21 PM
Well mine is a 61 with electric start no lights or extras I asked the seller about it will have to see what he says and hope it's correct.
Thanks again
#7 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted September 14, 2014 - 09:49 PM
The differences between the harnesses *should* be between magneto and battery ignition, right?
Ben W.
#8 bryan 110 OFFLINE
bryan 110
  • 222 Thanks
  • 293 posts
Posted September 15, 2014 - 10:47 AM
As far as I can tell the ebay one to oem it's the same thing I count 11conections (hard to count the rolled up ebay)but I count 11 so I bought it hope it works lol
#9 IHCubGuy OFFLINE
IHCubGuy
  • 1,611 Thanks
  • 1,638 posts
Posted September 16, 2014 - 03:37 PM
Ben W.
That's very possible.  I was thinking it was just between electric and recoil start but that wouldn't necessarily hold true either.  I say that because we have a 70 with magneto ignition and electric start on it.  I will have to look that over now as well to see how it varies between our other 70's with battery ignition.
#10 bryan 110 OFFLINE
bryan 110
  • 222 Thanks
  • 293 posts
Posted September 16, 2014 - 05:52 PM
The guy said it will work for any cub original ( 61) recoil key ect so I hope he's right lolif not I have some wires to use
