For Sale
Simplicity Legacy 3 Point Hitch, Cat 0 Or Cat 1 - $875 (Dorr, Mi)
2 replies to this topic
#1 Talntedmrgreen OFFLINE
  • 3,289 Thanks
  • 2,315 posts
Posted September 11, 2014 - 08:44 AM
This is a newly manufactured, 3 point hitch for Simplicity Legacy subcompact tractors. Factory hitches have not been available for years, and when available were well over $1500.
This hitch has improvements over OEM to reduce or eliminate wear points, and utilizes hardened, removable/adjustable lift arm pins vs the welded soft steel pegs on the factory design. Hitch also uses heavier 23" Cat1 lower lift arms and adjustable vertical lift arms to accommodate a wider variety of Cat0 and Cat1 3 point attachments and tractor uses. A Cat0 top link is included.   $875
This is not an OEM hitch. This hitch has vast improvements over OEM, and is built to have replaceable components such as the lift rocker trunion and rocker bushings and can be easily lubed where the factory hitch could not, to extend it's life well beyond that of the tractors it is designed for use on.
Hitch is complete, with lower lift arms, vertical lift arms, top link, mounting bolts and lift rod. Compatible with equivalent AGCO and Massey Ferguson tractors. This hitch does NOT fit Legacy XL or Sunstar tractors, but may with your own modifications to mounting points.
Installation is very simple, using only 6 bolts, in the factory configuration.
Please feel free to come take a look, or email with any questions. I can ship this via Fastenal freight, and the cost will probably be around $80-100, pending confirmation from Fastenal. Shipment would be to your nearest Fastenal store.
00h0h_drdYbUkwnB6_600x450.jpg00c0c_1bdJukEztuI_600x450.jpg00T0T_58791NETYtE_600x450.jpg00s0s_bZb9bJ3DC6M_600x450.jpg00c0c_j15OdcsRsUH_600x450.jpg00L0L_aYRYMmFTWXx_600x450.jpg01010_ICkGT3Jvvk_600x450.jpg
  • Traill95 said thank you
#2 I2R15TDI OFFLINE
I2R15TDI
  • 3 posts
Posted November 29, 2014 - 10:52 PM
I am very interested however I need a 1693447 (540 PTO) to attach this hitch on my legacy. Do you by chance know where I can find this? Thank you. Derek
#3 Talntedmrgreen OFFLINE
  • 3,289 Thanks
  • 2,315 posts
Posted November 30, 2014 - 03:41 PM
The pto is not needed in order to mount a 3pt....they are not integrated with each other.
The 540 pto's are very, very, very rare for these tractors. After I sold my spare legacy, I put the 540 pto on ebay for $900, and it sold immediately. I'm always watching for them, as I know several folks who would like one, but the two units I had are 2 of only 4 I have seen or heard of. Mine is serial # 368, so there has to be some out there.
