The Next Project On The List
cat d4
40 replies to this topic
#16 nbent ONLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted September 22, 2014 - 10:22 PM
Wouldn't smell any smoke from that stack!
no you don't and thats good when there wasn't anything there it was hard to drive
i changed the oil in the engine today and to my surprise no sludge at all i put some mmo in it to help a free up a ring
#17 nbent ONLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted September 28, 2014 - 01:33 AM
the pony motors alive and kickin got the valve freed up with some persuasion  and the stack is a little shorter now. i am definitely getting a muffler for the pony it is louder than the diesel motor
#18 KennyP OFFLINE
  • 40,036 Thanks
  • 46,727 posts
Posted September 28, 2014 - 05:29 AM
Sounds like you will be driving around the yard soon!
  • nbent said thank you
#19 nbent ONLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted September 28, 2014 - 11:55 AM
i have already done that  :D  :D  :D
im going to take the camera out and try to get a video of the start up
#20 nbent ONLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted September 29, 2014 - 09:37 PM
i got a video of the diesel start up and i will warn you its loud
  • MH81, grnspot110, Alc and 1 other said thanks
#21 nbent ONLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted October 04, 2014 - 12:53 AM
i removed the oil cooler today as it was leaking bad due to a rusty tube i took it to a local shop to have them clean it then fix the leaks in it
#22 KennyP OFFLINE
  • 40,036 Thanks
  • 46,727 posts
Posted October 04, 2014 - 05:05 AM
There are always some things that need a little extra TLC! Hope they can fix it for you.
#23 nbent ONLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted October 16, 2014 - 12:21 AM
still don't have the oil cooler back but i went and played saturday any way
#24 nbent ONLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted January 20, 2015 - 12:37 AM
just an update i forgot i had straight water in the cooling system and in the beginning  of the fall it froze and cracked the lower radiator housing cracked the main engine and the pony motor blocks. thankfully no internal damage i put in the shop Saturday night and worked on it Sunday i have the rad pulled and the exhaust manifold pulled i am thinking of pulling the head and having it checked for cracks and wear  along with checking the cylinder bores the pony motor needs to be removed for either rebuilding or replacing depending on how it checks out plus the injector pump and the governor to replace some leaking seals
#25 MH81 OFFLINE
Posted January 20, 2015 - 02:48 AM
I may have lost one as well. Be a couple days before I can get to it to check.
One thing drives out another.
#26 nbent ONLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted January 20, 2015 - 12:32 PM
i don't think its lost i did no internal damage on the main engine just cracked part of the side out it can be brazed or welded back together the same on the pony but it needs rebuilt any way
it always suck when you do lose one
#27 nbent ONLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted February 10, 2015 - 01:31 PM
She's coming along I found a guy who will sell me both engine blocks reasonably but I do have to swap over liners and everything on the main engine and only a few things on the pony motor plus I have some clutch work to do on it
#28 Utah Smitty OFFLINE
Utah Smitty
  • 1,705 Thanks
  • 1,789 posts
Posted February 12, 2015 - 04:44 PM
Good to see ya here, Nelson!! I wondered where you've been.
BTW, if that's a 2U series D4, Utah Track and Welding in Salt Lake  on west 2100 S (right by Lee-Kay range) had a couple in their yard.  They also have a hot line for construction equipment parts and can find stuff for you... Call 801 971-89 three 9, and ask for Alan.  Tell him Steve Smith sent you.
Smitty
  • Alc and nbent have said thanks
#29 nbent ONLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted February 12, 2015 - 09:20 PM
Yah I'm still here just busy with work and working on my stupid computer again right now this cat and my JD 318 are in the shop almost done with the JD and just starting on this cat. Sounds like the main engine head needs valves and guides
#30 nbent ONLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted March 14, 2015 - 05:04 PM
Well the new block and old one are completely gutted now its time to clean and reassemble I'm going to reuse all bearings and rings they all look great and are within specs
uploadfromtaptalk1426370482161.jpg uploadfromtaptalk1426370501787.jpg uploadfromtaptalk1426370519920.jpg uploadfromtaptalk1426370538785.jpg
