7117 Vs 7112 ?
20 replies to this topic
#16 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted September 15, 2014 - 10:16 AM
1988 6517 Was a cheaper tractor back then than the sun star.
I am having issues with the belt and mower deck. Now I use it for all my small towing needs, lawn roller dethatched and cart.
:D   Al
it looks like my allis 611 that has a broken input shaft . it also has a tiller that I wish I could use .
#17 alleyyooper OFFLINE
alleyyooper
  • 950 Thanks
  • 421 posts
Posted September 16, 2014 - 04:30 AM
I don't think the 6517 could run a tiller. The PTO engagement lever has a spot for mow and ST.
Was a good mowing tractor for me. I replaced one spindle and pulley on the deck when it kept shearing the pulley hold down bolt on the right side. Also about 6 drive belts 2 of which was in 2013 and with in minutes of each other.
Replaced the hydro drive belt twice the last just a couple months ago, Rebuilt the steering drag link when it was 2 years old. no problem since.
Engine has had ignition module changes on the third one now. A fuel pump and the normal oil changes and plug changes. One starter solenoid too.
:D   Al
  • alec said thank you
#18 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted September 16, 2014 - 08:11 PM
:D   Al
does it have a little knockout square on the lower right side of the back ?
#19 alleyyooper OFFLINE
alleyyooper
  • 950 Thanks
  • 421 posts
Posted September 17, 2014 - 05:33 AM
I will have to look.
:D   Al
#20 brokenflutes OFFLINE
brokenflutes
  • 22 Thanks
  • 17 posts
Posted September 18, 2014 - 11:41 AM
I have a 7117 with ag tires. It has a 17 hp K motor. It has the hydro lift and the lever on the side for fwd and rev. plus a high low lever. I also have a suburban with a manual lift. I adapted the hydro lift to the Suburban implements and use the hydro lift because lifting the weighted disc was more than I could do. Bottom line I'll take a hydro lift over manual any time now. Then again I am 62 but good luck with your new toy.
#21 alleyyooper OFFLINE
alleyyooper
  • 950 Thanks
  • 421 posts
Posted September 18, 2014 - 12:06 PM
No knock out hole in the rear.
:D   Al
