7117 Vs 7112 ?
20 replies to this topic
#1 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted September 08, 2014 - 07:06 PM
what is the difference and are parts and implements interchangable ? thanks in advance for all your help ..snark is also welcome :beerchug:
#2 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 08, 2014 - 08:39 PM
They have different #s stamped on them,one has 7117 and the other has 7112,that all I can tell you right now,but I will look it up...LOL(snark)
  • alec said thank you
#3 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted September 08, 2014 - 09:03 PM
:bigrofl: thats what I like !!
  • Auburn David said thank you
#4 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 08, 2014 - 09:35 PM
seems they are all "7100 SERIES HYDROSTATIC SEMI AUTOMATIC 6 SP TRACTORs"have diffrent engins and options from what I can tell..
#5 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted September 08, 2014 - 10:37 PM
so 6sp meaning there are 6 speeds in the gearing but I just push the lever right ?
#6 Talntedmrgreen OFFLINE
  • 3,273 Thanks
  • 2,306 posts
Posted September 09, 2014 - 07:29 AM
Hydrostatic and 6 Speed were different models with complete different transmissions.  You can't see both on one tractor.
The primary difference, is that they have different engines.  The 7117 has a KT17 Kohler twin, while the 7112 has a K301 single.  A hydrostatic tractor has the option of hydro lift, but the geared models do not.  I don't believe a 7117 could be had WITHOUT hydrostatic trans, unless specially ordered that way (know of one factory 7790 6-Speed...very rare).
Edited by Talntedmrgreen, September 09, 2014 - 07:30 AM.
  • alec and Auburn David have said thanks
#7 Sparky OFFLINE
Sparky
  • 1,298 Thanks
  • 1,892 posts
Posted September 09, 2014 - 05:38 PM
Today I was called to check an LPG Onan circa 1974 . It did not do an automatic run as scheduled . On a manual start it ran erratically at less than normal . Pulled one plug wire - no difference . Put wire back , pulled other plug wire , engine died . Testing done while " running " . I recommended total generator / engine replacement considering importance of equipment .
Two cylinders that should run versus one that did . Snarky maybe . I don't recommend handling live plug wires - they can tingle .
#8 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted September 09, 2014 - 05:40 PM
so is an electric lift on a 7112 a good or bad thing ?
#9 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,424 Thanks
  • 1,856 posts
Posted September 09, 2014 - 05:43 PM
Not really nothing wrong with it. Easier than manual and don't have to worry about leaks like with a hydraulic lift. However, I believe hydraulic lift units can lift more.
#10 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted September 09, 2014 - 07:03 PM
it comes with a manual also correct ? I am picking up my 7112 tommorow .
  • VintageIronCollector said thank you
#11 VintageIronCollector OFFLINE
  • 1,424 Thanks
  • 1,856 posts
Posted September 09, 2014 - 07:53 PM
it comes with a manual also correct?
If its the same as a 912 allis then yes manual lift would have been standard.
#12 Talntedmrgreen OFFLINE
  • 3,273 Thanks
  • 2,306 posts
Posted September 10, 2014 - 08:15 AM
Yes, the 7112 would be standard with manual lift, and have electric lift as an option if a 6-speed.  If it's a hydro, then hydraulic lift was available.  Electric lift is a great thing.  I'd take hydro lift over electric lift, but they both beat the heck out of manual lift.
The 7117's had hydraulic lift claimed to be 'standard' in the brochures, but I have seen them with manual lift.
#13 alleyyooper OFFLINE
alleyyooper
  • 939 Thanks
  • 419 posts
Posted September 13, 2014 - 08:07 AM
The 7112 I have is only a 3 speed transmission with a high low range lever on the right side. It is also a manual lift but I think the electric lift was a option as my dash decal has a place that says electric lift. It has been a very good tractor since bought new on May 5th 1972. Mowed grass with the 42 inch deck with no problem all those summers. Pushed wet sticky snow and minimal depths of snow also.
:D   Al
#14 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted September 14, 2014 - 11:29 AM
:D   Al
very nice al . what is the other one in front of it ? is that the simplicity version of the 811 allis ?
#15 alleyyooper OFFLINE
alleyyooper
  • 939 Thanks
  • 419 posts
Posted September 15, 2014 - 04:29 AM
1988 6517 Was a cheaper tractor back then than the sun star.
I am having issues with the belt and mower deck. Now I use it for all my small towing needs, lawn roller dethatched and cart.
:D   Al
