Converting To Pedal Power?
8 replies to this topic
#1 firefight100 OFFLINE
firefight100
  • 20 Thanks
  • 19 posts
Posted September 06, 2014 - 11:14 PM
Has anyone converted a 990 to use a foot pedal for direction?  Similar to the Ford 145's?  Doesnt look that hard to do.
#2 massey driver ONLINE
massey driver
  • 1,422 Thanks
  • 1,576 posts
Posted September 07, 2014 - 08:41 AM
And here I thought that you were going to do away with the motor and put Bike Pedals on to power the tractor.
  • LilysDad and Auburn David have said thanks
#3 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,295 Thanks
  • 9,777 posts
Posted September 07, 2014 - 01:18 PM
What are you going to use your hands for then?
#4 Cvans OFFLINE
  • 6,648 Thanks
  • 6,128 posts
Posted September 07, 2014 - 04:42 PM
Check with olcowhand (Daniel) as he has done this in the past.
  • firefight100 said thank you
#5 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,802 posts
Posted September 07, 2014 - 05:12 PM
I don't remember seeing any here but there were at least a couple conversion threads over at MTF.
#6 firefight100 OFFLINE
firefight100
  • 20 Thanks
  • 19 posts
Posted September 07, 2014 - 06:37 PM
MTF?
  • VintageIronCollector said thank you
#7 olcowhand ONLINE
  • 41,144 Thanks
  • 31,415 posts
Posted September 08, 2014 - 06:41 PM
Yes, did it to an Allis 416 years ago HERE.  Worked good, but not all hydro's react the same.  I also converted "Hogzilla", but the pedal was way too sensitive & hard to control, so I went back to hand control.  Actually, "Hogzilla" was a Bush Hog JBI originally equipped with foot pedal hydro, but I put a hydro/diff from a Simplicity Sunstar under it & wanted to go pedal.  It worked alright, but I couldn't get a handle on making it safe to use.  It would jump full speed forward or backward even when being very careful with foot movements.  I've never converted a 990 or anything with the Eaton hydro, so not sure how sensitive it would be.  Just adding a pedal to a 990 oughta be a piece of cake.  But the neutral detent & stabilizing the action might be a different story.
#8 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,424 Thanks
  • 1,856 posts
Posted September 08, 2014 - 06:43 PM
MTF?
My Tractor Forum
#9 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,951 Thanks
  • 1,865 posts
Posted September 08, 2014 - 06:57 PM
When I built up this 990 into a grader, I put a pedal on it so I could use the lever or the pedal.
This is the only photo that shows the foot pedal.   You can see below the drive lever.
Edited by jdcrawler, September 08, 2014 - 07:24 PM.
  • olcowhand, massey driver and firefight100 have said thanks
