What Was I Thinking- Homelite T-10 Hydro
36 replies to this topic
#31 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,367 Thanks
  • 3,321 posts
Posted November 28, 2014 - 11:41 AM
I threw the wood piece I had away since it was rotten on the bottom. So will cut a new one today. Thanks!
Edited by sacsr, November 28, 2014 - 01:13 PM.
  • Cat385B said thank you
#32 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,367 Thanks
  • 3,321 posts
Posted November 28, 2014 - 06:49 PM
Well I finally looked at the serial plate......hmmmmmm.....Model- T-12. Serial # 13470007
So I have a combination T-10 and T-12? Factory or one of the previous owners? Does the serial number have any significance?
#33 Cat385B ONLINE
    Therapy CAT
  • 12,537 Thanks
  • 9,288 posts
Posted November 28, 2014 - 07:50 PM
Your data sticker is in the correct place, I would go with replacement hood.
  • sacsr said thank you
#34 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,367 Thanks
  • 3,321 posts
Posted November 28, 2014 - 08:41 PM
So At some point someone combined two tractors,(since I have a 10hp briggs along with the hood). Well I bought it for a back up mower, so not a big deal. I do prefer the hydro for mowing.
#35 dodge trucker ONLINE
dodge trucker
  • 1,547 Thanks
  • 2,025 posts
Posted November 29, 2014 - 10:52 AM
Its built by Simplicity
yeah it does look like some of the Simplicitys I have seen, but I always thought Homelite and Jacobsen were part of the same company as I have seen a lot of their L&G stuff that had both names on it.  Homelite itself has seemed to "go away", do not see much of anything from them no more, not even like the hand held hedge cutters, weed eaters leaf bowers and such.
I had always associated Homelite and Jacobsen much like you would Camaro and Firebird... same stuff different emblems
#36 Cat385B ONLINE
    Therapy CAT
  • 12,537 Thanks
  • 9,288 posts
Posted November 29, 2014 - 02:35 PM
Homelite had Jacobsen build their garden tractors after 1976.
#37 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 5,844 Thanks
  • 2,670 posts
Posted December 08, 2014 - 09:35 AM
When we put this tractor together out of the crate from the factory there was no board between the battery and the motor. I put a piece of metal in there just to make sure it didn't slide forward to the motor. Even though it had hold down bolts on both sides of the battery we still did this. Over the years and many, many, many batteries later the hold down bolts and clips were lost or put away and a rubber bungee was used to hold it. Last spring I changed the hold down and repainted the battery box. Put down a bed of natural rubber and fashioned a new hold down for the battery. Works well. Recently I was going through a couple of boxes that came from my dad's garage. I found the original clips and bolts for the battery. The original battery was the size of a car battery back then. Just thought I would throw this out there for you.        Roger.
  • KennyP, sacsr and Cat385B have said thanks
