What Was I Thinking- Homelite T-10 Hydro
36 replies to this topic
#1 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,365 posts
Posted September 06, 2014 - 08:57 PM
I have always liked the look of these GT's- just not sure where I am going to put it. Says no spark so may be a challenge for me to get it running.ImageUploadedByTapatalk1410054987.862764.jpg ImageUploadedByTapatalk1410054997.452578.jpg ImageUploadedByTapatalk1410055005.573573.jpg ImageUploadedByTapatalk1410055014.462397.jpg ImageUploadedByTapatalk1410055022.938700.jpg
  • Alc, Texas Deere and Horse, hamman and 7 others have said thanks
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted September 06, 2014 - 09:12 PM
I attribute the no spark problem to an apparent lack of a battery.
  • MH81, sacsr, boyscout862 and 1 other said thanks
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted September 06, 2014 - 09:17 PM
I bet that if you polish the points/replace the condenser/replace the spark plug, you'll have fire.
Ben W.
  • sacsr and boyscout862 have said thanks
#4 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted September 06, 2014 - 09:22 PM
Was that the one on E-bay? Unless there was a lot of bidding at the end, you got a great deal!
Should be an easy fix. I thought about it, but way to far for me.
  • sacsr said thank you
#5 Littledeere ONLINE
Littledeere
  • 1,649 Thanks
  • 1,481 posts
Posted September 06, 2014 - 09:29 PM
That looks like it will be a nice unit and I'm with Ben I bet it does not take much to get it going
#6 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,365 posts
Posted September 06, 2014 - 09:38 PM
Yes it was the one on eBay. $177.50 I thought it was a pretty good deal for its condition. Have no idea what is correct or incorrect on this tractor. But it was pretty! :thumbs:
Edited by sacsr, September 07, 2014 - 08:56 PM.
#7 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted September 06, 2014 - 11:20 PM
The only non-original part I see is the fuel shutoff. What's the white spot above and left of the choke knob? That's where the electric lift switch would be.
#8 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,365 posts
Posted September 06, 2014 - 11:32 PM
Don't know. Guess I will find out when I pick it up this week. I don't know much about these Homelites. How well do they mow?
#9 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted September 06, 2014 - 11:42 PM
I had a T15 with the 48" deck. It mowed better than a:
Husqvarna zero turn, Jacobsen Turfcat, JD 212 or 318, JD 185, Bolens G152, and was equal to a JD 322 with the 50 deck.
  • Texas Deere and Horse and sacsr have said thanks
#10 KennyP ONLINE
  • 37,526 Thanks
  • 45,518 posts
Posted September 07, 2014 - 05:12 AM
Good looking T-10, Scott! Good luck with it!
#11 boyscout862 OFFLINE
  • 12,551 Thanks
  • 9,044 posts
Posted September 07, 2014 - 05:44 AM
Its built by Simplicity and they mow very well. I have a large herd of GTs. The AC/Simplicitys are a snappy and fun tractor. They are second only to Bolens in number of attachments that were available. You did real well. Look up the flip cart that they had. You will want one to go with your T - 10. Good Luck, Rick
#12 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted September 07, 2014 - 05:59 AM
Very nice GT. I'm with you on that being a nice looking GT
#13 HANKG OFFLINE
HANKG
  • 6,203 Thanks
  • 3,382 posts
Posted September 07, 2014 - 06:26 AM
Nice looking ride good deal too
#14 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,365 posts
Posted September 07, 2014 - 06:43 AM
So I am doing research, I believe it was an Allis built GT. But it shows a gear driven not hydro driven tractor?
Good to know they mow well.
I do need a back up mower, since none of my BH have a deck on them, so maybe it can be my back up. (Got to justify my purchase).
Figuring its a manual lift because of the long handle on the left??? Or could it be both manual and electric?
#15 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted September 07, 2014 - 07:26 AM
Yep, it's manual lift. I wasn't sure if all the models came with the hole punched out for the electric lift switch.
That one was built by Allis Chalmers. It has a blue right hand discharge deck, it has large round headlights instead of the dual twin lights, and the grille is wider at the bottom than the top. And it has electric clutched pto pulley out the front of the engine.
Here is a Simplicity built Homelite:
  • KennyP, sacsr and skunkhome have said thanks
