Draft Plate Stuck
2 replies to this topic
#1 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted September 06, 2014 - 04:53 PM
The pins that hold the draft plate to the frame on my 210 are stuck I have tried pb blast also a punch and hammer and hasn't budged any idea before I cut it off
#2 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted September 06, 2014 - 07:03 PM
Heat on the sliders then soak with PB.
  • GTTinkerer said thank you
#3 lyall ONLINE
lyall
  • 2,180 Thanks
  • 1,577 posts
Posted September 06, 2014 - 08:49 PM
can you remove the roll pin part #2 from the pin fastener #1
than you should be able to pull the pin fastener out
remove the rust that has build up on the pin fasteners ( both side ) and grease them before you put them back together
