What's Missing On This Case Snowplow?
7 replies to this topic
#1 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted September 06, 2014 - 10:03 AM
My friends 220, attached the plow, missing the lifting arm & I would assume the bracket. Can someone confirm this and which ones I will need for him?
Thanks!
#2 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 06, 2014 - 10:10 AM
  • A.C.T. said thank you
#3 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted September 06, 2014 - 10:45 AM
Well I know that isn't stock.
#4 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 06, 2014 - 10:52 AM
No I dont believe it is stock,LOL..but I bet it works good!
#5 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 06, 2014 - 10:55 AM
not sure if this is relevant or not http://s433.photobuc...html?sort=3&o=5
#6 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted September 06, 2014 - 08:18 PM
Don't argue.  You know you like it.
Ben W.
#7 gopher OFFLINE
gopher
  • 761 Thanks
  • 756 posts
Posted September 06, 2014 - 08:36 PM
Older style plow all he needs is lift bar goes over axle. Whats wrong when he hooked it up he flipped the lift arm easy to do if not watching for it you have to completely disconnect to flip it back where it belongs.
#8 breimer OFFLINE
breimer
  • 132 Thanks
  • 164 posts
Posted September 06, 2014 - 11:00 PM
A lift bar yes and then possibly a bracket as I don't see where to hook the rear of the bar to. My 224 has that lift arm built differently and has a spot to put the bar on. Don't see that spot/pin that mine has.
