Jake 1450 Electric Lift Question?
jake super chief jacobsen 1450 jacobsen electric lift
28 replies to this topic
#1 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Posted September 06, 2014 - 09:17 AM
I do not have a complete working lift for this tractor. If someone would, give me the travel distance of the lift itself. I have an idea to make this a hydraulic lift, but need to know if any cylinders I have would work for it.
#2 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 06, 2014 - 09:37 AM
I put a lift on a Craftsman GT5000,Used an old trim motor and cylinders off a boat...works like a charm,with the box blade mounted it will pick up the back end of the machine with calcium filled tires. will also pick me up when I stand on it(225lbs)
#3 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Posted September 06, 2014 - 11:16 AM
I have that setup. And a GM style power steering pump. Just need to see how much travel there was in the original lift. The trim cylinders I have are about an 8" stroke. But I have a couple 4" stroke from Ford tractors and valves!
  • Auburn David said thank you
#4 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 06, 2014 - 11:29 AM
Mine are probably around 8" as well,gives really good down pressure.
#5 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Posted September 11, 2014 - 04:22 AM
Anyone with a Manual lift Jake and a tiller? Still looking for the stroke for the Jake lift mechanism!
#6 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 11, 2014 - 08:15 AM
#7 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Posted September 11, 2014 - 08:27 AM
Not sure! What is that for?
#8 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 11, 2014 - 08:38 AM
said its for a 1450,lift,but its and old page and there isnt any info on it.
#9 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 11, 2014 - 08:42 AM
My bad,that seems to be for a 1450 Cub...
#10 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 11, 2014 - 08:46 AM
when I search Jacobsen 1450 seems all that comes up are Cubs...
#11 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 11, 2014 - 08:52 AM
There is this thread on here http://gardentractor...ief-slot-hitch/
#12 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Posted September 11, 2014 - 09:27 AM
I was hoping he would post in here!
#13 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Posted December 22, 2014 - 08:49 AM
Still looking for the stroke length for an electric lift on this 1450. I have tiller parts coming and would like to know how to set up a lift on here.
#14 RAJ OFFLINE
RAJ
    JMC fan
  • 324 Thanks
  • 323 posts
Posted December 22, 2014 - 10:07 AM
I have a Ford 140 with an electric lift. I can try to measure the distance later today.
#15 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Posted December 22, 2014 - 10:38 AM
Thanks! I hope I can make this a hydraulic lift, but need to know what stroke cylinder I will need!
Also tagged with one or more of these keywords: jake super chief, jacobsen 1450, jacobsen electric lift
