Wisconsin Tra-10D Governor Springs And Adjustment?
13 replies to this topic
#1 IamSherwood OFFLINE
  • 8,390 Thanks
Posted September 05, 2014 - 06:53 AM
I'm trying to get the carb and governor set up on the TRA-10D
on my Bush Hog D4-10.
I just received new springs and adjusting screw from Bolens 1000.
Being the adjusting screw, and springs are so conveniently located behind
the carb, which makes adjusting a challenge, does anyone have any
pictures or tips or tricks or advice that might make this process a bit
easier?
Thanks
#2 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,364 posts
Posted September 07, 2014 - 07:18 AM
Will what type of picture do you need? I rarely have to mess with the setup, when I have, The carb was off.
  • IamSherwood said thank you
#3 Bolens 1000 ONLINE
  • 14,902 Thanks
  • 18,101 posts
Posted September 07, 2014 - 07:38 AM
Carb will have to be off for installation of the new rod and spring.
Usually its just a set it and forget it, once you install the rod and spring.
#4 IamSherwood OFFLINE
  • 8,390 Thanks
Posted September 07, 2014 - 07:55 AM
What I'm trying to find out, is how much of the adjusting rod, is in service.
In other words, how much tension on the governor spring?
#5 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,364 posts
Posted September 07, 2014 - 08:01 AM
I will have to look
#6 Bolens 1000 ONLINE
  • 14,902 Thanks
  • 18,101 posts
Posted September 07, 2014 - 08:13 AM
I usually adjust mine to the "Idle position" (Throttle control pushed all the way in)
I make it so there's just enough tension on the spring to keep it from dropping down on the points cover.
  • Alc, IamSherwood and sacsr have said thanks
#7 Kfs35 OFFLINE
Kfs35
  • 408 Thanks
  • 416 posts
Posted September 08, 2014 - 10:38 AM
That's how I set mine, too.
  • Alc and IamSherwood have said thanks
#8 IamSherwood OFFLINE
  • 8,390 Thanks
Posted September 10, 2014 - 06:11 AM
It's supposed to rain later today, so maybe I'll get some shop time.
Thanks for the input.
#9 IamSherwood OFFLINE
  • 8,390 Thanks
Posted September 12, 2014 - 06:28 AM
I believe I have the Governor and adjustment screw set right, and have the correct springs
installed, but it's still giving me grief. It starts easily, and runs strong at mid throttle, smoothly
increases rpm when throttle is pulled further out. Problem is that when I go to idle, it promptly
dies. It almost seems like it's running away at times. I thought it might be sucking some air, so
I sprayed carb cleaner at the intake manifold gasket. No change. Spraying at the gasket between
the upper and lower halves of the carb, at the front of the carb, caused a cough or 2. I was a bit
suspect about that seal at that point when I had the carb apart and reassembled. There isn't
a bolt there to suck the 2 halves together.
Could one drill and tap there, or should I try to seal it with something? If so, what?
The pic is from before I took the carb apart. Previous owner did have some sort of sealant
smeared on the gasket around the front of the carb.
#10 Kfs35 OFFLINE
Kfs35
  • 408 Thanks
  • 416 posts
Posted September 12, 2014 - 02:19 PM
I used a file to true the two halves to try to get it to seal better. Go slow, the aluminum cuts pretty quickly with a good file.
#11 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted September 12, 2014 - 02:26 PM
A good sized piece of glass with a sheet of 400 grit sandpaper works very well for getting the surfaces flat also.
#12 Bolens 1000 ONLINE
  • 14,902 Thanks
  • 18,101 posts
Posted September 12, 2014 - 04:43 PM
I think your springs are backwards, the PM61 goes on the top and mounts to the air cleaner hose coming out the valve cover. The PM200A goes on the bottom and is your gov. spring.
usually filing them down gets the job done on the warped carbs, that was caused by the previous owner over tightening the screws....
#13 IamSherwood OFFLINE
  • 8,390 Thanks
Posted September 12, 2014 - 05:27 PM
I have the long spring on top, connected to the tube coming out of the valve cover, and the shorter
one on the bottom. I don't know about the part #s, as they arrived in one bag together.
I'll give a file, and sandpaper on glass a try.
Thanks guys.
  • Bolens 1000, Texas Deere and Horse and sacsr have said thanks
#14 Bolens 1000 ONLINE
  • 14,902 Thanks
  • 18,101 posts
Posted September 13, 2014 - 07:56 AM
Thanks guys.
Short one goes on the bottom, long one goes on the top (Silver colored one)
  • IamSherwood and sacsr have said thanks
