Simplicity Landlord 101 Transaxle.
5 replies to this topic
#1 Bill56 OFFLINE
  • 839 Thanks
  • 2,179 posts
Posted September 03, 2014 - 05:50 AM
Sometime, in the future, I'd like to do some investigating to find the cause of all the slop in the transaxle of my 101. I know, from other repair experiences, that it can be cheaper to replace a whole unit rather than try to buy parts separately. So, just for a "what to be looking for" reference, what models of Simplicity or AC tractors used the same transaxle?
Thanks, Bill
#2 HANKG OFFLINE
HANKG
  • 5,595 Thanks
  • 3,087 posts
Posted September 03, 2014 - 06:04 AM
Landlord or sure AC B1 I Think also
  • Bill56 said thank you
#3 Talntedmrgreen ONLINE
  • 3,162 Thanks
  • 2,239 posts
Posted September 03, 2014 - 10:32 AM
The 101 has some slight differences from a 700/725/B-1 transaxle assembly.  Nothing that wouldn't prevent it from being a bolt-n-go swap, but there are some minor linkage changes in the clutch and brake, as well as a lack of axle tube over the LH side of the axle.  The BGB drive pulley may not have a slip clutch feature that was added in the Landlord series to protect the BGB from shock.
Any 3 speed trans 1959-1970 should bolt right in.  Later ones may as well, but I can't say for sure if they share the same bolt pattern.  I'm going to be doing one myself next week and can document if you like (away on vacation).
#4 Bill56 OFFLINE
  • 839 Thanks
  • 2,179 posts
Posted September 04, 2014 - 06:25 AM
Thanks, that would be helpful.
#5 the_nite_owl OFFLINE
the_nite_owl
  • 6 Thanks
  • 9 posts
Posted September 26, 2014 - 11:53 AM
I would be interested as well.  I have the transmission from a 65 Broadmoor that might make a good backup.  Does that also mean the Hi/Lo setup from the Broadmoor could be used on an early Landlord?
I have two 101s and a 2010.
Any chance the late 60 early 70 Broadmoor transmissions would work?
#6 Talntedmrgreen ONLINE
  • 3,162 Thanks
  • 2,239 posts
Posted September 26, 2014 - 12:03 PM
No...the small frame lawn tractors have an entirely different transaxle than the large frame garden tractors. The hilo is different as well.
