Truck Repair Suprises.
5 replies to this topic
#1 dropped82 ONLINE
dropped82
    Nut Case
  • 2,493 Thanks
  • 1,816 posts
Posted September 02, 2014 - 07:56 PM
My 02 Silverado needs ball joints. It actually only needs one but I decided to do all. Then after price searching, I'm just replacing all the control arms. Well after pulling (cutting bolts) the lowers, I find that since the bolts were seized they managed to wear out the holes. Considering a wallowed out hole will never aligned right, I grab some 5/8" grade 8 washers, my grinder, and welder. Here is a before pic.
This is actually one of the better ones. Others were worn as much as a 1/4". Hopefully this will do good. I just finished. It got dark on me so I will have the after pics tomorrow.
Eric
  • HDWildBill, boyscout862 and Sawdust have said thanks
#2 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 02, 2014 - 07:59 PM
Yep,thats how we do it also,but never used the washers,always replated and drilled..thanks for that info!
  • boyscout862 and dropped82 have said thanks
#3 dropped82 ONLINE
dropped82
    Nut Case
  • 2,493 Thanks
  • 1,816 posts
Posted September 02, 2014 - 08:54 PM
I was thinking of filling them also but the metal is pretty thin. Figured adding washers would not only fill the worn spots but also make it a little thicker at those points.
Eric S.
  • HDWildBill, boyscout862 and Auburn David have said thanks
#4 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 03, 2014 - 08:57 AM
Eric S.
And thats a great idea,let me know how it turns out!
  • dropped82 said thank you
#5 dropped82 ONLINE
dropped82
    Nut Case
  • 2,493 Thanks
  • 1,816 posts
Posted September 03, 2014 - 07:28 PM
Here is the after pic. I took a bunch but I think just this one pic says it all. This was probably the worst hole. I went ahead and did all 8. They all had wear. Some more than others obviously. The extra support wouldn't hurt anything.
This idea was actually taught to me by my FIL. We were working on another project where a drilled hole was mis-measured and close to an edge. The washer solved the problem.
Eric
  • Texas Deere and Horse, HDWildBill and Auburn David have said thanks
#6 Texas Deere and Horse OFFLINE
  • 14,796 Thanks
  • 15,495 posts
Posted September 03, 2014 - 07:34 PM
Good repair Eric, should hold up as long as the rest if the truck lasts now.
