Onan
50 replies to this topic
#1 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 02, 2014 - 03:48 PM
Ok just got this tractor home and it is smoking and no power it has the onan cckb ms 2440 on it so my guess is a broken ring any onan guys out there can give me advice my guy says 50 a hole to bore it what else should I ask him
  • FrozenInTime said thank you
  • 14,811 Thanks
  • 15,499 posts
Posted September 02, 2014 - 04:24 PM
I would first check the valve seals and guides and pull the heads to de-carbon them. That will also look at the bore and see if they have any scoring.
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted September 02, 2014 - 07:13 PM
Smoking is not a good thing in an Onan because parts are not cheap.
My questions to ask would be whether it is oil burning or excess gas.  You CCKB should have an adjustable carb I think.
See if the oil is too full or too thin (i.e., fuel is in the oil).
If it has sat for some time, which means a ring is stuck in place, guys have reported all sorts of miracles from SeaFoam or Marvel Mystery Oil in the gas or oil.
Ben W.
  • Alc and Texas Deere and Horse have said thanks
#4 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 03, 2014 - 12:54 AM
I am going to pull the heads and take a peak anyone have all the clearance specs and torque specs for a cckb I don't think it is the valve seat it is all cast iron block and seats I was told could be carbon the guy I bought it from said a guy told him he had just rebuilt it right before he bought it
#5 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 03, 2014 - 11:30 AM
Any other things or pitfalls I need to be aware of
#6 FrozenInTime OFFLINE
FrozenInTime
  • 654 Thanks
  • 402 posts
Posted September 03, 2014 - 03:51 PM
http://onanparts.com...bcat=0&sort=20a
Thought I had more but that's all I could find bookmarked on this puter.
#7 toppop52 OFFLINE
toppop52
  • 5,254 Thanks
  • 4,757 posts
Posted September 03, 2014 - 07:57 PM
http://www.partsfort.../onan®-m-8.html
ASAP, extremely honest and fair.
#8 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 03, 2014 - 08:10 PM
Ok thanks a lot that's a big help
#9 speedex99gt OFFLINE
speedex99gt
  • 43 Thanks
  • 52 posts
Posted September 10, 2014 - 09:08 PM
When you pull the head of move the piston to the top and see if you can move it back and forth. If it rocks back an forth then you will be needing a rebuild. But my suggestion would  be to repower it with something else.
#10 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 10, 2014 - 09:30 PM
No I can't do that. To repower this would be sacrilege . I will rebuild but never repower it
Tim
Edited by Tim Bergfeld, September 11, 2014 - 08:37 AM.
  • Cat385B and speedex99gt have said thanks
#11 KennyP ONLINE
  • 38,302 Thanks
  • 45,899 posts
Posted September 11, 2014 - 04:14 AM
If it has just been rebuilt and not ran very much, the rings may not be seated as yet!
#12 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 11, 2014 - 06:56 PM
Oh boy I just took the heads off of this thing and it's not a pretty pictureImageUploadedByTapatalk1410479710.456481.jpg
ImageUploadedByTapatalk1410479729.538850.jpg ImageUploadedByTapatalk1410479739.688863.jpg ImageUploadedByTapatalk1410479760.122318.jpg ImageUploadedByTapatalk1410479768.289053.jpg
Tim
#13 KennyP ONLINE
  • 38,302 Thanks
  • 45,899 posts
Posted September 11, 2014 - 07:16 PM
That doesn't look like a recent rebuild to me!
#14 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 11, 2014 - 07:28 PM
Here are some after I cleaned it up
Tim
#15 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 11, 2014 - 07:29 PM
ImageUploadedByTapatalk1410481728.704334.jpg ImageUploadedByTapatalk1410481744.221561.jpg ImageUploadedByTapatalk1410481753.954879.jpg ImageUploadedByTapatalk1410481771.202519.jpg
Tim
  • Alc, Texas Deere and Horse and KennyP have said thanks
