Hydraulic Lift Control
4 replies to this topic
#1 Tankman OFFLINE
Tankman
  • 298 Thanks
  • 299 posts
Posted September 02, 2014 - 05:34 AM
Workin' on my "new" '95 1641, wiring and carb problems getting done. OK!
While sitting on the Cub, engine not running, should the lift / lower lever move? Is this, doesn't move at all, another issue?
Any ideas or is this OK while the engine isn't running? Might the hydro lift lever move when the engine runs of is this a problem the previous owner didn't "mention?"   :deadhorse:
#2 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted September 04, 2014 - 08:23 PM
On your 1641 which is comparable to my 1864. My hydraulicleverwillmove no t h sausages engine is off , but of course will only let the implement down.
  • 14,730 Thanks
  • 15,470 posts
Posted September 04, 2014 - 08:26 PM
Not sure what this means?
  • GTTinkerer, Sawdust and Gabriel have said thanks
#4 ACecil OFFLINE
ACecil
  • 460 Thanks
  • 339 posts
Posted September 05, 2014 - 09:50 PM
The hydraulic lift lever shouldn't move when the engine is off.
#5 Tankman OFFLINE
Tankman
  • 298 Thanks
  • 299 posts
Posted September 06, 2014 - 08:56 PM
 Thanks! I was ready to remove the lift lever ass'y.
Currently tryin' to get the 16 hp Briggs runnin', on its' own.
Replaced fuel pump, removed carb top and cleaned. Must 've missed something.
Engine runs usin' carb cleaner spray but, shuts down after the spray stops.
Fuel pump (new) is working.
Where might I take a look? Any help is appreciated.
4-years, Camp Lejeune. Had great times in NC!
