Continental 2 Cyl Flathead - Rebuilt - $260 - Mn
19 replies to this topic
#16 Texas Deere and Horse OFFLINE
  • 14,665 Thanks
  • 15,449 posts
Posted September 02, 2014 - 03:30 PM
Another neat engine was the ford small block that I believe Joy air compressor co. took and let one side of the V8 make compressed air with while powering it with the other side of the engine. It made a very compact 175+CFM portable compressor.
The dist. cap is factory is they could use the same distributor in more then one engine. Hope someone here gets it, it would make a neat conversion engine.
#17 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,476 Thanks
  • 2,811 posts
Posted September 02, 2014 - 04:38 PM
Going by it's size compared to our Minneapolis Moline's 4 cylinder Continental, I'd hazard a guess of 12 to 15hp, and I doubt it's 15.
I believe that a cub farmalls engine is only 9hp with tis 4 cylinders, so this one might be as low as 5hp. Kind of need to know the bore and stoke to figure it out. I've seen some engines like this one used to power pumps on tank trailers of the mid to late 60's. Most of them used a 2cylinder wissy engine like a TD.
#18 olcowhand OFFLINE
  • 38,800 Thanks
  • 30,699 posts
Posted September 02, 2014 - 04:57 PM
Yes, I agree Jeff, very hard to guess without even something in the pic for a size reference.
#19 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted September 02, 2014 - 07:30 PM
The M88A1 used a 2 cylinder Continental to power the auxiliary power unit but it was a diesel.  The APU put out 24 volts to charge the batteries and run all the hydraulics except the main and boom winches.
#20 Cat385B ONLINE
    HAZMAT CAT
  • 13,139 Thanks
  • 9,619 posts
Posted September 02, 2014 - 09:54 PM
Response from seller stated he bought it as shown, owner before him thought it was off a hydraulic pump. The search continues.
