Didier Hydraulic Sickle Mower - Bolens? - Central Mn $250
5 replies to this topic
#1 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted September 01, 2014 - 07:30 AM
Located in Central MN: http://minneapolis.c...4646325990.html
5" belly mount sickle mower for a mid sized garden tractor. I believe it was on a 20 horse older bolens. I purchased this to put on my Kabota & never got it mounted. It is hydraulic & has its own oil tank. Tank may need replacing. Needs to be pto driven off of your garden tractor. 3/4" x 7/8" pto shaft. No tractor mounting hardware, you would have to fabricate that. Sickle Mower has the mounting hardware. Made by Dider Manufacturing Co. Racine, Wi.. Model #11271, code B, Serial #100753. Front mount pins are 14 1/2' apart, rear pins are 13 3/4" apart & front to rear pin centers are 20 1/2" apart.
#2 Talntedmrgreen OFFLINE
  • 3,238 Thanks
  • 2,302 posts
Posted September 01, 2014 - 07:41 AM
Im very interested but dont see the photos he mentions? Cat, is this far from you?
#3 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted September 01, 2014 - 07:46 AM
Little over an hour. I tried the ad on three different browsers, no pics. Have you dared a text yet?
I get nothing on searching the model #, I am assuming it is for a Bolens since I can't find any contradictory info. The driveshaft size is correct for a Bolens.
:bigrofl:
Josh is out in the garage under tractors measuring....... :poke:
#4 wilberj ONLINE
wilberj
  • 4,990 Thanks
  • 5,590 posts
Posted September 01, 2014 - 10:02 AM
^ Dont sound Bolens.
#5 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted September 01, 2014 - 11:12 AM
Can't think of another make that uses 7/8" x 3/4" driveshaft. I wonder if info could be had from Haban since they bought out Didier?
#6 Talntedmrgreen OFFLINE
  • 3,238 Thanks
  • 2,302 posts
Posted September 01, 2014 - 11:16 AM
I see a variety of these with various model #'s for compact tractors when searching online. I texted early today with no response. Id love to try it on my Legacy.
