Jake Gets A Muffler
jacobsen 1450 jacobsen super chief
27 replies to this topic
#1 KennyP ONLINE
  • 40,986 Thanks
  • 47,152 posts
Posted September 01, 2014 - 04:41 AM
I got Jake this Spring. It came with a straight pipe and remnants of a muffler. Very loud. After trying to find a muffler to fit it with no luck, I decided to make one. I started with a muffler off a B&S 15HP OHV engine. This had something rattling around inside, so I took it apart to investigate. Found the guts had fallen into several pieces. After a little trimming here and there, I came up with a new piece for the inside. I opened the holes up to match closer to the Kohler K301 exhaust. Found a piece of auto exhaust for a new inlet pipe. It sits further out than a stock muffler, but it has a longer body and this also gives me good access to the dipstick.
Here's a pic from when I got it.
Here's the muffler pics.
I noticed there was gas seepage at the bottom of the tank.Took it off and after some cleaning, found several issues. Now, to fix this. Not sure whether to go get some .023 wire and weld it, or to use a fuel tank repair kit on it.
  • Bill56, tinbender7, CRFarnsworth and 2 others have said thanks
#2 TomLGT195 OFFLINE
TomLGT195
  • 4,055 Thanks
  • 2,903 posts
Posted September 01, 2014 - 06:11 AM
Nice job on the muffler, bet it sounds better now. Tom
  • KennyP, tinbender7 and boyscout862 have said thanks
#3 TomLGT195 OFFLINE
TomLGT195
  • 4,055 Thanks
  • 2,903 posts
Posted September 01, 2014 - 06:14 AM
Kenny, what brand and size are the rear tires?
#4 KennyP ONLINE
  • 40,986 Thanks
  • 47,152 posts
It's much quieter! Now to fix the gas tank. Then on to other things that need a little TLC.
#5 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted September 01, 2014 - 06:39 AM
Kenny, best way to fix metal fuel tanks o have found it to solder them. And if the metal is gone or hole too large, you can patch them easy with solder. Just need to use a really good flux and muriatic acid with a brush to clean the metals really good. JUST MAKE SURE YOU WASH EVERYTHING SUPER GOOD AFTER YOUR DONE!!! Or it will be a rust ball in a day or so. Its easy and you can make the solder look like it was welded ;-)
  • KennyP, tinbender7, Chopperhed and 2 others have said thanks
#6 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,440 Thanks
  • 1,860 posts
Posted September 01, 2014 - 06:44 AM
KennyP why didn't you just buy this one? It's a factory replacement. Although I do like yours better tho! Nice work :thumbs:
  • KennyP and tinbender7 have said thanks
#7 KennyP ONLINE
  • 40,986 Thanks
  • 47,152 posts
Posted September 01, 2014 - 06:56 AM
They are 23X10.50-12 Carlisle Tru-Power's. They were on my LGT165, but with the engine down, stuck them on here for now.
Thinking along that line too. The hole is larger now. It is mighty thin and opened more as I cleaned the area. Found 2 more small holes nearby. What flux would be good? Not sure what I can find today! I do have some silver solder too.
Those are pretty noisy and I didn't want to try taking the 'stock' pipe off the engine. The bolts there are very rusty.
  • TomLGT195 said thank you
#8 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted September 01, 2014 - 06:57 AM
Nice work Kenny. The way you got it it looks more like a loudener than a muffler. It must have blatted out quite a racket like that.
#9 ckjakline OFFLINE
ckjakline
  • 1,145 Thanks
  • 1,136 posts
Posted September 01, 2014 - 07:54 AM
JB weld also works well for fixing holes in fuel tanks.
#10 Bill56 OFFLINE
  • 842 Thanks
  • 2,179 posts
Posted September 01, 2014 - 08:01 AM
Nice job, Kenny! That should work for a long time.
#11 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted September 01, 2014 - 08:02 AM
OK Kenny here is the liquid flux Iuse the paste is of the same brand. Dont use silver solder it needs to be too hot and will warp the dickens out of it.
  • KennyP, TomLGT195, Sawdust and 1 other said thanks
#12 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted September 01, 2014 - 08:14 AM
The tank on my 125 was like that and it came out AWSOMEusing this stuff.
Edited by skyrydr2, September 01, 2014 - 08:16 AM.
#13 KennyP ONLINE
  • 40,986 Thanks
  • 47,152 posts
Posted September 01, 2014 - 08:26 AM
Here is what it looks like now after cleaning the area. The hole is pretty big!
#14 Sawdust ONLINE
Sawdust
  • 6,154 Thanks
  • 3,549 posts
Posted September 01, 2014 - 10:26 AM
I think you could still solder that. I agree silver solder needs to get hotter & I have used muriatic acid many times soldering & I like it. As mentioned clean it good, don't get it too hot & don't hang your head over the fumes, then clean it good again & prime. Jr weld would be a good alternative as well. It looks good how you brought it out with the auto pipe.
Edited by Sawdust, September 01, 2014 - 10:27 AM.
#15 KennyP ONLINE
  • 40,986 Thanks
  • 47,152 posts
Posted September 01, 2014 - 04:21 PM
Tried soldering. That was a no-go as my little iron wasn't up to the task. Mapp gas was too much heat. Ended up welding the best I could, then JB Weld to stop the pin holes. If someone has a decent tank they want to part with, PM me!
Also tagged with one or more of these keywords: jacobsen 1450, jacobsen super chief
