B10 Trans Issues-Wont Go Fwd Or Reverse.
7 replies to this topic
#1 eriklane OFFLINE
eriklane
  • 10 Thanks
  • 40 posts
Posted August 31, 2014 - 09:22 PM
Was out using it and it started making lots of odd jerks, but was going along...I stopped it at some point and now wont go into any gear. Bought 2 yrs ago from a guy that went through the whole thing. Hardly put 25 hours on it in 2 yrs.
Where do I start?
#2 MH81 OFFLINE
Posted August 31, 2014 - 09:29 PM
Sounds like the clutch isn't releasing the belt and/or the brake isn't working well.
Will it go into gear if the engine isn't running?
#3 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted August 31, 2014 - 10:17 PM
Is it grinding while you try to go into gear or is it just "stuck" and won't engage.
Ben W.
#4 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted September 01, 2014 - 06:10 AM
   Try to take the drive belt off the rear differential, if ti will start and run then your trouble is in the rear differential, if it still wont start and run witht the drive belt of then your trouble is in the bevel gear box.  Were you changing gears allot when it quit driving?  I have seen old tractor rear end's get stuck between gears but that usually only happens when you are changing gears in a hurry or get rammy with the shift lever.
    Start with the small stuff, take the drive belt of, if it runs then jack up the rear end and try to spin the wheels, I the wheels spin freely try to spin the input shaft.  This sounds like you may need to take the rear apart to fix it which is not to bad a job.  You may have pulled the side of one of the shift gears of, I had a friend who did that by shifting to hard, there are little plates on the sides of all the shift gears so that when you put the trans into neutral or got to change gears your shifting fork hits that plate and pulls the gear into place.
   Keep us informed!!!!!!!!  And :wewantpics:
#5 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted September 01, 2014 - 07:29 AM
  • Bill56 and davidj927 have said thanks
#6 eriklane OFFLINE
eriklane
  • 10 Thanks
  • 40 posts
Posted September 19, 2014 - 07:01 PM
Finally got to this-pinion gears are all ground up, the diff gear is a mess. 2 of the long bolts going through the pinion gears had no nuts, and 4 total were loose, so the thing flopped around and mashed it up to hek.
So, where can I find 2025444 and 2025445 parts?
#7 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted September 19, 2014 - 10:07 PM
That'll do it!
#8 eriklane OFFLINE
eriklane
  • 10 Thanks
  • 40 posts
Posted September 20, 2014 - 09:01 PM
Another thing is this-the hub has 2 threaded holes, mine has nothing in them. Should there be screws there and what is that for? Do they need to be tightened to secure the hub to the axle?
