Rack & Pinion Steering
6 replies to this topic
#1 junkman OFFLINE
junkman
  • 127 Thanks
  • 58 posts
Posted August 31, 2014 - 09:00 PM
I got a Case project I have been working on and have been having a hard time getting the steering down. Well the nephew is a VW guy with a bunch of junk ones to scavenge parts from. Had this brainstorm of utilizing the rack & pinion steering minus the power part of it ( i wish I could have utilized the power) and with a little more tweaking of the length, I think it just might work. Not your typical GT project, and is still too wide for standard garden tractors, but thought I would post just to maybe through out an idea.
#2 TomLGT195 OFFLINE
TomLGT195
  • 3,465 Thanks
  • 2,659 posts
Posted September 01, 2014 - 06:08 AM
Keep us posted, interested to see how it turns out. Tom
Edited by TomLGT195, September 01, 2014 - 06:08 AM.
  • junkman said thank you
#3 JDBrian OFFLINE
  • 9,599 Thanks
Posted September 01, 2014 - 07:12 AM
That's an interesting project. It would be a big improvement over most GT setups.
#4 junkman OFFLINE
junkman
  • 127 Thanks
  • 58 posts
Posted September 02, 2014 - 08:01 PM
Well I got the rack & pinion finished and ready too mount. Was not super easy with inadequate tools but I think it turned out really good and will work better then any other option I had in mind. Might post a pick when I get it bolted onto the frame in a few days. Then I will have this done and out of the way and then on to so, so many more brainstorms to get the project completed. Junkman.
#5 junkman OFFLINE
junkman
  • 127 Thanks
  • 58 posts
Posted September 10, 2014 - 10:18 PM
Well I said I would post a pic of my modified rack & pinion after getting it mounted, and must say it is much better then any other options I had thought of. Just wish the whole project was done but no such luck.
Edited by junkman, September 10, 2014 - 10:19 PM.
#6 Alc ONLINE
  • 6,421 Thanks
  • 7,231 posts
Posted September 11, 2014 - 05:32 AM
Fit in there really nice  :thumbs:   I wonder if a power rack could be run length wise and use just one tie rod and remove the rear facing one at the inner tie rod socket ?
#7 junkman OFFLINE
junkman
  • 127 Thanks
  • 58 posts
Posted September 11, 2014 - 08:19 PM
ALC, I think you could and in doing so you would make it pretty narrow for more applications. I have one just like that that came off a golf cart which I thought about just adding one more tie rod end too but settled with what I got. I see the gears are starting to turn in the ol brain I see.
