Jac Chief Speed Reducer Removal
20 replies to this topic
#16 KennyP OFFLINE
  • 37,451 Thanks
  • 45,472 posts
Posted January 13, 2015 - 08:32 PM
Thanks for posting all the pics! And the written info. I looked through most of those different models. Looked like the pics were all the same.
  • VintageIronCollector said thank you
#17 old tractors rock OFFLINE
old tractors rock
  • 1 Thanks
  • 2 posts
Posted June 21, 2015 - 07:36 AM
did you ever get the transmission rebuilt.. i am in the beginningarrow-10x10.png stages of rebuilding 2 tractors (jacobesen/ford) and i have to repair the speed reducer on oneIMG_20150613_164333.jpg
#18 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,421 Thanks
  • 1,855 posts
Posted June 21, 2015 - 08:52 PM
did you ever get the transmission rebuilt.. i am in the beginningarrow-10x10.png stages of rebuilding 2 tractors (jacobesen/ford) and i have to repair the speed reducer on oneattachicon.gifIMG_20150613_164333.jpg
no i hadn't. but maybe the other guy did
#19 VintageIronCollector OFFLINE
  • 1,421 Thanks
  • 1,855 posts
Posted July 20, 2015 - 09:06 PM
If anyone out there plans to rebuild a speed reducer here's the parts that get worn out and might need to be replaced:
JAC342558 Gasket
JAC342563 Ball Bearing
JAC331572 Oil Seal (2)
JAC342529 Thrust Washer (2)
JAC342560 Needle Bearing
JAC342561 Needle Bearing
JAC342776 Thrust Washer
JAC308554 Needle Bearing
JAC458432 Snap Ring
  • KennyP, Joe Knife and MikeTheGardenTractorGuy have said thanks
#20 Tennblue59 OFFLINE
Tennblue59
  • 451 Thanks
  • 522 posts
Posted July 31, 2015 - 06:41 PM
Old Tractor, I kinda got it fixed. I got it all back together and set near the Jacobsen, but haven't put it back in yet. I ended up painting and doing some other work on it and was easier to get it done with the axle still out. Then a couple other projects popped up......
I am gonna try and get it back together in the next couple weeks.
#21 VintageIronCollector OFFLINE
  • 1,421 Thanks
  • 1,855 posts
Posted September 05, 2015 - 11:58 PM
I had put this project on the back burner for a long time but today I got off the gear reducer. Now I have to pull the trans from my 800 and take off that gear reducer and put on this trans because the one in the 800 now the hubs are shot.
