Ingersoll 6018/dig-188T
11 replies to this topic
#1 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted August 31, 2014 - 11:43 AM
Hello all.new to the group and this type of board as well.
I just got a Dig-it 188t,and cant find much info on the little girl anywhere,but it looks alot like a ingersoll 6018 from what I have seen online.
 Got it with no engine but I found a nice Kohler Magnum 18 that I got cheap..but the braked for the hydro pump is gone so I will need to make/find a new one.
 i also have this dream of putting a QD on the loader and installing a hydro deck of a Jacobson turfmaster 428 on this machine,but not sure if I will need 2 pumps or not.Thanks to you all,lots of good info on this site!
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,778 Thanks
  • 9,918 posts
Posted August 31, 2014 - 12:03 PM
You can get the manuals for a 6018, which should have the pump # listed. You could check the specs from there. The hydro drive 72" deck on the Jacobsen I had was driven by a seperate pump than the machine's hydro system. Luckily, the 6018's pump puts out a lot of oil at a higher psi than found in any GT and even beats most SCUTs. I think it might work.
  • Auburn David said thank you
#3 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted August 31, 2014 - 12:37 PM
Thats great news!!!I have no idea how to tell when someone responds to my post on here,so it took me awhile the find your reply.
 Do you think the Dig-it and 6018 are close enough to use the sam manual?
#4 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted August 31, 2014 - 12:44 PM
Got a hurt hand,so my typing sucks..sorry.
#5 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Posted August 31, 2014 - 03:02 PM
Ingersoll supplied the tractors with backhoe sub frames Dig-it put there backhoes on and badged them Dig-it 188t the tractor is a Ingersoll 6018
  • sacsr and Auburn David have said thanks
#6 Cat385B ONLINE
    HAZMAT CAT
  • 13,778 Thanks
  • 9,918 posts
Posted August 31, 2014 - 05:38 PM
As gopher stated, the only difference is the backhoe. Digg-it's can reach farther and deeper.
I don't see the manual in our library. Check this link:
http://eastmanind.co...LsOw=&tabid=196
#7 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted August 31, 2014 - 06:19 PM
Yep!!!thats her for sure!Thank you both so much!!!!
#8 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted August 31, 2014 - 06:41 PM
I just got a Kohler Magnum 18 I am going to put on it,cant wait to get it going.
#9 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted August 31, 2014 - 06:44 PM
Guess I use 5W-40 in the hydrolics..same as a 6018?
#10 Cat385B ONLINE
    HAZMAT CAT
  • 13,778 Thanks
  • 9,918 posts
Posted August 31, 2014 - 06:59 PM
Yes, all Ingersoll or Case units use motor oil in their hydraulic drive systems.
#11 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted August 31, 2014 - 07:10 PM
Original paint on this little tractor was white/red,but its yellow now..not sure what color to go back with.
#12 Cat385B ONLINE
    HAZMAT CAT
  • 13,778 Thanks
  • 9,918 posts
Posted August 31, 2014 - 11:45 PM
I vote for the original paint scheme.
