Bolens 944 Articulating Front Mount , One Owner Arrived Today !
65 replies to this topic
#46 Bolens 1000 ONLINE
  • 15,432 Thanks
  • 18,284 posts
Posted September 15, 2014 - 06:58 PM
I take it this is just for show?
Lots of Bondo going on there!
#47 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted September 16, 2014 - 10:53 AM
No , not for show , for SNOW :bigrofl:
  I can't stand nasty looking welds and it is easier to wipe the snow off when it is nice and smooth.
   I got it sanded and painted and it looks much nicer.
  Next I will sand and paint the blade yellow .
  • BTS said thank you
#48 BTS ONLINE
BTS
    Make Stuff Up
  • 4,642 Thanks
  • 2,616 posts
Posted September 16, 2014 - 09:28 PM
Looking good! :worshippy1:
Edited by BTS, September 16, 2014 - 09:28 PM.
  • Don Campbell said thank you
#49 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted September 17, 2014 - 10:53 AM
Thanks ,
   Todays pic shows the blade painted yellow . Now I am trying to figure out the wiring . Several were just ripped out so it could be tricky. I ordered a new plastic gas tank because the old one was leaking even more on the bottom. I got a new spark plug, new fuel filter and fuel line for the engine . I hooked up the new throttle cable yesterday . The exhaust has one broken stud so this thing really should have gone to the junkyard :wallbanging:
   When I removed the wiring harness water came out of it too. :hitting_self_roller:
#50 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted September 17, 2014 - 04:42 PM
I worked some on the wiring today and got sidetracked on the exhaust system . I changed the down pipe and lower muffler to a up pipe with a chrome stack . :thumbs:
   People ask me why I never made my big model projects run and I tell them no-one wanted to pay the extra $10,000.00 or I would have. Starting with flat sheets of steel was the tricky part. Slapping a motor , pump , orbit motors, hoses, valves, etc. is the easy part, the expensive part too :thumbs:
  • EricR and BTS have said thanks
#51 BTS ONLINE
BTS
    Make Stuff Up
  • 4,642 Thanks
  • 2,616 posts
Posted September 17, 2014 - 10:23 PM
Ooooo , Could you make me a cat D11 just like it that's drivable!!!!! :dancingbanana:
I don't care if you spend a extra $10,000.00 on it, I mean since your already buying :poke: :firejumper: :smilewink:
You do incredible work! :worship:
Keep it up, I enjoy watching your builds :thumbs:
Edited by BTS, September 18, 2014 - 10:09 PM.
#52 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted September 18, 2014 - 08:29 AM
Thanks ,
   Todays first project was to fix the steering column . It had a full inch of play side to side and 1/2 in play up and down. I built a slotted bracket to slide over the shaft and fasten to the floor . No more play now !!   As little as I will ever use this machine it was a easy fix. Besides the steering shaft cable pulley was also rust welded on. :wallbanging:
#53 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted October 02, 2014 - 10:58 AM
Removed transaxle today after the first test drive failed. I shimmed the main pulley drive shaft a full 1/16th in. up and down play . Also replaced detent shifter ball bearing after I see it was wedged in one of the detent holes. :thumbs: I will test drive it again this afternoon .
  • TAHOE said thank you
#54 dave8338 OFFLINE
dave8338
  • 196 Thanks
  • 374 posts
Posted October 02, 2014 - 02:40 PM
What is all that red [grease] you have smeared in there for?
#55 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted October 02, 2014 - 04:44 PM
The grease is how it came , not gear oil ,  so it must have grease back then.
  Second test drive was also a failure , I had a fellow stop by and he said everything looks good except the shifting forks were real bad. He guaranteed that is the problem. So now were trying to order some shifting forks off e-bay. He said most of the 5 speed peerless transaxles back then had the same shifting forks. So hopefully I can match up my numbers with something on e-bay :thumbs:
#56 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted October 03, 2014 - 07:11 AM
My whole life I have drooled over this awesome machine . A few years ago I saw one with a cab and attachments for $10,000.00
  I could never afford one but the secret is this is what I was trying to copy with my little FS-11 project. I realize it is far from it but all I could afford. :D
#57 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted October 03, 2014 - 10:50 AM
I am being told the shifting forks for the Peerless 5 speeds are all 1/4 inch wide . Mine is also and mine is 2-9/16" long . So I am getting close to finding the right ones. You can see in this picture one of the forks that is broke. I am still very excited that the forks could be the problem all along. This could be the reason it was parked and never used again for 5 years until I bought it .
#58 Bolens 1000 ONLINE
  • 15,432 Thanks
  • 18,284 posts
Posted October 03, 2014 - 02:42 PM
I think your color is a bit off then...........
:poke:
#59 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,140 posts
Posted October 03, 2014 - 03:52 PM
:poke:
No, it's not           : default.jpg             :poke:  :poke:
  • Bolens 1000 and farmerall have said thanks
#60 Bolens 1000 ONLINE
  • 15,432 Thanks
  • 18,284 posts
Posted October 03, 2014 - 03:55 PM
No, it's not                    :poke:  :poke:
