'95 1641 Ignition Switch
3 replies to this topic
#1 Tankman OFFLINE
Tankman
  • 298 Thanks
  • 299 posts
Posted August 26, 2014 - 07:48 PM
Rec'd a new ignition switch from Partstree.com. :reading_the_manual:
The switch looks fine, the main wiring harness plug for the switch is in ruins, no big deal. I can handle that.
The new key'd ignition switch has one extra spade connection, different angle, close to the switch's edge. Might the spare connection be a ground (green?) wire connection?
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,779 Thanks
  • 9,918 posts
Posted August 26, 2014 - 08:02 PM
The extra tab above the top tab is labeled 'G', so I bet your right on it being a ground. Must be a MTD or Troy-Built application that needs that.
  • superaben and Tankman have said thanks
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted August 26, 2014 - 08:08 PM
Some use that lone tab as input for engine electrical charge to feed to the battery.  Simplicity lawn tractors are prone to that.
Ben W.
  • Tankman said thank you
#4 Bud W OFFLINE
Bud W
  • 311 Thanks
  • 296 posts
Posted August 27, 2014 - 11:50 AM
In my experience with these, the G tab is tied to ground. When the switch is turned off, G is connected to the M (magneto type ignition) terminal to ground out the spark. This type is used on the tractors with the plastic dash (where the switch mounts) to get the switch case grounded so it could kill the spark.
  • Cat385B said thank you
