Need Help To Find Snow Blower Pulley's!
4 replies to this topic
#1 mikemedic3 OFFLINE
mikemedic3
  • 2 posts
Posted August 26, 2014 - 10:08 AM
Hi guy's and Gal's. I have a GTV 18 in great shape but the snowblower 842-20261 needs pulley's, they are rotted out. I have tried sears parts but of course they don't make them any more. The pulley I really need is the drive  that power's the auger, it's a double pully of different size Think it's part number 9776, plus need the one that ride on the other side of it (parallel). Any idea's where to look? don't believe I can make this part as I initially thought. Trying to post everywhere. I have been sitting here for hours searching forums with no luck.
#2 Lmiller3358 OFFLINE
Lmiller3358
  • 1,400 Thanks
  • 1,368 posts
Posted August 26, 2014 - 04:27 PM
Dang, I'm looking to find a sight I was on a while back look for one myself...
#3 MH81 OFFLINE
  • 28,446 Thanks
  • 29,126 posts
Posted August 28, 2014 - 04:33 AM
Missing parts like that can really throw a wrench into the best plans.
Good luck in your search. Do you know the pulley sizes at least?
#4 mikemedic3 OFFLINE
mikemedic3
  • 2 posts
Posted September 01, 2014 - 09:32 AM
The pulley size (with tape) is a 6" and 5" the inner opening is somewhere near 15/16 with bearings, the bearing are in good shape which I can swap out, but can't find the pulley's yet. My other thought is I can cut the shafts off the mount and weld on new ones' that would fit newer pulley's that I find, just a lot easier to swap out pulley's.
#5 MH81 OFFLINE
  • 28,446 Thanks
  • 29,126 posts
Posted September 01, 2014 - 09:38 AM
If I were you, I would take as many precise measurements as possible.
ID, OD, belt width and pitch, offset if any... Then call a place called Erie Bearing in Meadville PA. They are often miracle workers.
  • mikemedic3 said thank you
