Picked Up A Bolens H16
54 replies to this topic
#46 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22769 Thanks
  • 7527 posts
Posted April 30, 2016 - 05:13 PM
Nice Job - looking good.  If the gear ratio inside the gearbox is identical then the deck blades will run a bit faster with the larger pulley and probably take a little bit more power to drive it - you may want to check the ratio of the gear boxes to make sure they are identical and also if you have room for the larger pulley to fit without hitting anything.  There may be enough give in the tensioner spring but I would think you may need a slightly longer belt with the 4" pulley.
  • LPBolens, Sawdust and Bolens800uk have said thanks
#47 Sawdust OFFLINE
Sawdust
  • 6801 Thanks
  • 3799 posts
Posted June 01, 2016 - 07:47 AM
Well once again got started on painting my seat & then it snowballed into another repair job. The outer plastic trim ring needed repaired. I used some webbing & JB weld to reinforce.
I wire brushed the seat pan, used rust converter then painted.
I got some wiring done decided to replace all of it & solder the connections...hate searching for loose connections. I also reconnected both safety switches because these had been cut off.
I always wondered how I got tranny fluid up on the top of the fender pan, hole in the top of the reservoir, repaired with JB weld.
Got the hood on, looks kind of like a storm trooper on star wars. I have an expense problem on the decals. This tractor was the early version using the black, gold & white with the Husky dog in the headlight area. These will cost about $45. more compared to the I believe one year later version having the FMC decal. I have to decide how authentic I want to be, this will be a worker mostly cutting grass not a show piece. Being the perfectionist I am & knowing the whole time driving this tractor I know I would be more happy knowing that the dog is out there on my hood instead of the FMC so I may have a delay in my progress right now. :D
  • LPBolens, Bruce Dorsi, blackjackjakexxix and 4 others have said thanks
#48 Sawdust OFFLINE
Sawdust
  • 6801 Thanks
  • 3799 posts
Posted June 14, 2016 - 09:14 PM
Well finally got her out of the corral after a very long stay with some repairs & some painting done. Even though it wasn't a total rebuild just some minor repairs & making things like the wiring, sleeves & bushings updated. Two things I learned to do. One was to put the L brackets on the dash box before mounting the fender pan & seat. Don't install the battery tray until EVERYTHING is done in that area, dropping something down into the tube frame is like the abyss. My extendable magnetic rod was my friend several times.
I still need a few things done like Plasti-Coat the rubber knobs that are white, put some kind of pull knob on the parking brake.
I have to get some head lights...not really wanting the typical GE 4411 which has some bad reviews lately for not lasting long. The Wagner brand has some better reviews. I need some for my other GT's so maybe I'll order about four pairs when I do.  I need to decide on the decals also, as I mentioned earlier this is the older version with the Husky dog & gold, black & white. These are more expensive. Sam from Sam's Bolen's gave me a quote & I know he makes some good products so I'll probably go with him but later. I really need to get this GT back to work cutting grass.  I used a spray vinyl from Dupli Color to cover the bad white over spray from the PO...really pleased. I didn't feel any need to go original on the tail lights since this wasn't a restore. I got these from a trailer supply called etrailer for $2.50 each & $2.99 shipping, I bought two pairs & really happy with them. Any questions & comments like always are welcomed. Thanks everyone for looking & supporting me on another project.
pic51.jpg pic52.jpg pic54.jpg pic55.jpg pic56.jpg pic57.jpg pic58.jpg pic59.jpg
  • Bolens 1000, LPBolens, blackjackjakexxix and 3 others have said thanks
#49 ClassicBolens OFFLINE
ClassicBolens
  • 1527 Thanks
  • 516 posts
Posted June 14, 2016 - 10:53 PM
Looking good. I especially like your clean wiring job. Very well done.
  • Sawdust said thank you
#50 fonz3482 OFFLINE
fonz3482
  • 1913 Thanks
  • 890 posts
Posted June 15, 2016 - 05:45 AM
Great job and very sharp machine!! I believe a lot of guys here use click it and stick it for decals. I've heard good things about their decals.
#51 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22769 Thanks
  • 7527 posts
Posted June 15, 2016 - 09:22 AM
Nice looking tractor and great job on painting the seat - it looks really sharp.  Can't wait to see it with new decals - thanks for sharing.
#52 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted June 15, 2016 - 10:36 PM
Nice job,really looking good
#53 Hydrohusky OFFLINE
Hydrohusky
  • 42 Thanks
  • 43 posts
Posted June 16, 2016 - 01:36 PM
attachicon.gifSeat.pngattachicon.gifseat5.jpgattachicon.gifseat8.jpgattachicon.gifseat7.jpg
I’ve truly enjoyed following your work.  Your patience and attention to detail is inspiring.  I learned a few body work techniques as well.  I’ve always had an interest in the H14, 1556 and H16 tractors and owned or helped friends with quite a few.  I believe they’re very reliable and the Tecumseh engines with proper maintenance and cleaning seem to run forever.
The hole in the hydraulic fluid reservoir was put there during manufacture.  I've witnessed it on every Eaton 10 Bolens that uses the tank.  (recently on a 1256)  I believe it allows the reservoir to act as an expansion tank.
Also, in an earlier post you mentioned the transmission seeming a little ‘jerky’.  My experience has been this is more related to the drive belts and tensioning spring than the hydrostatic package.  You mentioned you may be using a non-OEM tensioning spring.  When the hydrostatic package is called to accelerate or slow the tractor the load on the drive shaft and ultimately the drive belt spikes.  There is a lot of deflection on the Bolens drive belts and you can see the tensioner spring fight to keep the belts taught.  As the belts flutter, you can feel some unevenness in movement.  The correct spring makes a world of difference.  Too much spring pre-maturely destroys the belts.  Last note is the Eaton 10 as driven on a Bolens does like the engine RPM up towards the top of operating range.  (3000 to 3,600 rpm)
  • WrenchinOnIt and Sawdust have said thanks
#54 Sawdust OFFLINE
Sawdust
  • 6801 Thanks
  • 3799 posts
Posted June 19, 2016 - 07:10 PM
Hydrohusky I was wondering why that hole was punched out from the inside so I guess I'll be repairing my repair. :mad2:  When I bought new belts I realized the drive belts I took off were 2" too long so I was slipping & jerking bad. Once I got back in the saddle I could tell a big difference...very strong.  My two PTO belts were too long also, they actually broke the belt guard twice trying to throw the belts off.  Your also right about the high RPM's needed.
This Bolens was a much more easier tear down than my MTD 990 & the MF12. Since it's running much more stronger than before I'm going to follow through with the sleeve hitch build soon.  Thanks again for your compliments. ​ :thumbs:
  • Hydrohusky said thank you
#55 Rainier OFFLINE
Rainier
  • 682 Thanks
  • 557 posts
Posted May 25, 2019 - 11:02 PM
Well I thought all I would do since this is a good runner but looks bad is clean up, make some minor repairs, paint & enjoy...not. I couldn't stand the flat black so I took the fender pan off & started what I thought would be an easy repair of a few dents, prime & paint. I started sanding & found a lot of rust not too much pitting but looks like the PO took the white off but didn't prep the old rust. Having that do it right or don't do it all mind set I got the sand blaster out & got started. A lot more work but I had to do it right. I know if I didn't do this the rust would start creeping through that new white paint next year or not long after.
Here is the rust I found under the black paint
The center section looks like something tried to bite it
I had to improvise on not having any body workers dolly tools so I used a hammer & some pieces of iron pipe nipples.
attachicon.gifFender pan6.jpgattachicon.gifFender pan7.jpgattachicon.gifFender pan8.jpg
I flattened a few fender dents then sanded to show up the high & low spots. I will Bondo these tomorrow
Sand blasted & primed with Rustoleum's Self Etching Primer
Once I get this done I'll do the hood & grill the same way hopefully it won't be as bad. I'm not going to finish coat until I clean the tractor up & do some tweeking. I know this tractor originally had an off white color almost a cream but I'm leaning more to a brighter white & the frame semi gloss or satin black. Thanks for looking!
I have the paint code for that off white cream color. I got it matched off my H14. It looks nice. Some day I’m going to paint my 1556 with this color as well. If interested pm me and I’ll make sure you get the code for the paint mix.
