Kohler K482 Vacuum/pulse Fuel Pump.
6 replies to this topic
#1 TokyoDrift99 OFFLINE
TokyoDrift99
  • 81 Thanks
  • 112 posts
Posted August 24, 2014 - 01:22 AM
My Kohler k482 know seems to have a bad fuel pump. Can I drill a hole in the intake manifold, run a vaccuum line and use a cheap briggs pulse pump? (These engines use a mechanical pump activated by a arm that rides on lobe on the cam) A aftermaket pump will cost me almost $90, and a Kohler part will cost me about $130. The Briggs vanguard pump will run me $16 shipped for a genuine Briggs part... The Kohler service manual states "certain applications use pulse pumps which are furnished by the equipment manufacturer." Opinions?
Vanguard pump: http://www.amazon.co...9&robot_redir=1
#2 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted August 24, 2014 - 07:28 AM
I don't see why it wouldn't work.  Let us know what happens.
Ben W.
#3 Alc ONLINE
  • 6,905 Thanks
  • 7,468 posts
Posted August 24, 2014 - 08:10 AM
Doesn't the vacuum line go into the crankcase to get  the pluses ?
#4 Bud W OFFLINE
Bud W
  • 326 Thanks
  • 303 posts
Posted August 24, 2014 - 09:04 AM
If you take the pump off and replace it with a plate with a barb fitting it works great.
#5 TokyoDrift99 OFFLINE
TokyoDrift99
  • 81 Thanks
  • 112 posts
Posted August 24, 2014 - 10:20 AM
Alright, I'll make a plate and I planned on using a barb on the manifold, but now I don't have to drill a hole in it. Thanks!
#6 TokyoDrift99 OFFLINE
TokyoDrift99
  • 81 Thanks
  • 112 posts
Posted August 24, 2014 - 10:41 AM
Should I go with this metal body mikuni unit? I'm pretty sure it can be opened up and rebuilt, if it fails.
http://www.amazon.co...#ref=mp_s_a_1_5
#7 TokyoDrift99 OFFLINE
TokyoDrift99
  • 81 Thanks
  • 112 posts
Posted August 24, 2014 - 01:58 PM
Well I made the plate. It's just some scrap so it don't look to pretty. But with a little permatex it will work great. I have to go to the hardware store tomorrow to get that barb fitting.
