A New To Me Simplicity Coming Home
70 replies to this topic
#16 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 06, 2014 - 10:32 PM
Ok so here we go need a part number for an air filter and what's the best way to de crud this carb and need an oil filter number and the hydraulic fluid weight and filter number. They have an Stp oil filter on for the hydraulic filter I believe those filters are way to fine to filter. Lots of blue smoke so going to run a compression check first thing
Edited by Tim Bergfeld, September 06, 2014 - 10:38 PM.
#17 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted September 06, 2014 - 11:04 PM
Onan air filter Part Number: PA2347, Baldwin
Transmission filters:
Part Number: 51307, WIX
Part Number: 85307*, Car Quest
Part Number: 1307*, NAPA,
Part Number: B163, Baldwin
Oil Filters for Onan CCKB 19.5 HP
Part Number: S3600, STP
Part Number: 85516, Car Quest
Part Number: 51516, WIX
Part Number: B243, Baldwin
  • sacsr said thank you
#18 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted September 06, 2014 - 11:12 PM
Hydraulic fluid is Dexron II.
#19 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 07, 2014 - 07:36 AM
Wow thanks
#20 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 07, 2014 - 12:48 PM
I know some people here swear by sea foam to clean the carb. my question is how do you guys do it ? I have the iv bottle that you use on a car but that hooks into a vac line for the break booster how do you guys do it on your tractor ?
Edited by Tim Bergfeld, September 07, 2014 - 12:50 PM.
#21 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted September 07, 2014 - 03:03 PM
Dribble pour directly into the carb, slowly increasing flow until it dies. I try to stretch it out for at least 10-15 seconds of smoky mess.
#22 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 07, 2014 - 04:06 PM
Ok
#23 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 07, 2014 - 08:18 PM
Lol every time I look at this thing I find something else to fix
#24 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 07, 2014 - 08:28 PM
It was just a total neglect. At least it is right at 105 psi in both cyl but it is smoking a lot not sure about the cause but I know the carb is awful gummed up and the plugs have a ton of carbon and the spark looks a little weak. Was busy getting the front end fixed today does anyone make bushings for the front axle these have plenty of wiggle
#25 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted September 07, 2014 - 09:12 PM
Not sure on the front axle pivot, but we're almost through a whole page without any pics. I'll do some digging.
#26 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted September 07, 2014 - 09:15 PM
How do you move that hog around without it running? Is it simply putting the range selector in Neutral, or is there a hydro release somewhere?
#27 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted September 07, 2014 - 09:19 PM
Neutral in the 3 speed rear.
  • Cat385B said thank you
#28 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 07, 2014 - 09:32 PM
lol I am sorry I looked like a ground hog today with the front end I will take some tomorrow
#29 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 07, 2014 - 09:45 PM
Ok here is a peek at the neglect so far but for what I paid I can sell the mower deck and break even
ImageUploadedByTapatalk1410144175.804004.jpg ImageUploadedByTapatalk1410144187.554429.jpg
And a couple little rust holes to weld up on the mower deck ImageUploadedByTapatalk1410144262.753936.jpg
#30 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 08, 2014 - 12:44 PM
Ok update new plugs and sea foam in the carb it runs a lot better still misses some and the governor keeps kicking in and out but at least it will idle and run. Oh yeah I got the front end fixed one of the center pivot bolts had no nut on it and the other was not tight. And the compression is around 105 both cyl ImageUploadedByTapatalk1410197939.150543.jpg
The above pic is the pivot bolt for the front I thought the front end was gone to fall out from under it it was so lose. ImageUploadedByTapatalk1410198041.133177.jpg thats how the front should look. ImageUploadedByTapatalk1410198215.733155.jpg this is a happy guy on his 400 dollar mower
Tim
