* - - - - 1 votes
D200 Home
41 replies to this topic
#1 fogler12538 OFFLINE
fogler12538
  • 284 Thanks
  • 170 posts
Posted August 23, 2014 - 09:51 AM
My nephew ended up delivering it to me Thursday night for the cost of fuel. The loader works great. Will lift the front end off the ground no problem. The tractor runs great after some messing with, it just won't move. The hydro pump sounds like it's working just not getting any movement. Anyway this is my 400 dollar D200
IMG_20140823_103754.jpg IMG_20140823_103825.jpg IMG_20140823_103842.jpg post-59557-0-55632400-1408805474.jpg post-59557-0-97386400-1408805489.jpg
Edited by Texas Deere and Horse, August 23, 2014 - 12:09 PM.
Rotated Photos
  • Alc, Texas Deere and Horse, sacsr and 3 others have said thanks
#2 fogler12538 OFFLINE
fogler12538
  • 284 Thanks
  • 170 posts
Posted August 23, 2014 - 09:53 AM
Sorry about the upside down pics I don't know what happened
#3 Cvans ONLINE
  • 6,649 Thanks
  • 6,130 posts
Posted August 23, 2014 - 10:14 AM
No matter how you look at it that's a good deal.  :D
  • boyscout862 and fogler12538 have said thanks
#4 boyscout862 ONLINE
  • 12,862 Thanks
  • 9,174 posts
Posted August 23, 2014 - 11:34 AM
Great deal. Read the manuals. Probably a blocked filter, low fluid, or maybe wrong fluid. Good Luck, Rick
  • fogler12538 said thank you
#5 Texas Deere and Horse ONLINE
  • 14,812 Thanks
  • 15,501 posts
Posted August 23, 2014 - 12:10 PM
What a GREAT deal, the loader is worth the price and the D-200 is a free bonus. Did you check to make sure the free wheel valve is closed?
#6 fogler12538 OFFLINE
fogler12538
  • 284 Thanks
  • 170 posts
Posted August 23, 2014 - 12:19 PM
I couldn't really get on the free wheel valve. I tried from underneath with an open ended wrench and couldn't budge it. Is a square nut and sockets wouldn't go on the nut through the hole by the brake petal. The manual says to use 10-40 or 10-30 in the transmission . I have the filter just haven't done it yet
#7 Texas Deere and Horse ONLINE
  • 14,812 Thanks
  • 15,501 posts
Posted August 23, 2014 - 12:28 PM
Sitting on the seat, there is a hole in the frame of the tractor about where your ankle would be. If you look through the hole, you should see a bolt with a slot in the end of it for a large slotted screw driver. Use a slotted screw driver to rotate the bolt.
  • Alc, KennyP, sacsr and 2 others have said thanks
#8 fogler12538 OFFLINE
fogler12538
  • 284 Thanks
  • 170 posts
Posted August 23, 2014 - 01:16 PM
Through that hole is a 5/16 share nut with no slot . it looks factory because of the red paint . I can get a 5/16 wrench on it from under neat but can't budge it
#9 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted August 23, 2014 - 01:50 PM
Just got back from vacation. That is great looking tractor for $400!
So you did get it running?
All the freewheel valves I have seen are a slotted screw type. You can remove the side panel that is blocking your access  to the bolt pretty easily, I think its just 4 screws hold the panel. I am thinking that its not the factory screw. If you get it out give us a pic please.
#10 fogler12538 OFFLINE
fogler12538
  • 284 Thanks
  • 170 posts
Posted August 23, 2014 - 01:53 PM
Running great
#11 olcowhand ONLINE
  • 41,202 Thanks
  • 31,432 posts
Posted August 23, 2014 - 01:56 PM
In my book, $400 for just the loader is a bargain!!!!!!!!  That is a super GREAT deal!
#12 fogler12538 OFFLINE
fogler12538
  • 284 Thanks
  • 170 posts
Posted August 23, 2014 - 02:02 PM
I can't see how to take it off without taking off a bunch of other stuff
#13 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted August 23, 2014 - 03:14 PM
My 1974 D-200 has a square headed bolt instead of the slotted type.
Mine is square also. Did you try to turn the square headed bolt/plug in both directions?
It only needs turned 1 complete reveloution to go from drive to tow, or from tow to drive.
Some of my Wheel Horse autos the tow valve gets turned 90* and some get 1/2 turn, and my D is 1 complete turn.
By the way, you got a very good deal for the tractor & FEL!
Edited by KC9KAS, August 23, 2014 - 03:15 PM.
#14 fogler12538 OFFLINE
fogler12538
  • 284 Thanks
  • 170 posts
Posted August 23, 2014 - 03:33 PM
I can't seem to get a socket on it. I tried for about an hour with no luck. I can get a wrench on it from below but I'm not in a good position to turn it. It won't budge
#15 fogler12538 OFFLINE
fogler12538
  • 284 Thanks
  • 170 posts
Posted August 23, 2014 - 03:47 PM
I was going to change the fluid and filter after my wife goes to work . should I use motor oil like the manual say or ATF . getting conflicting info from other sites
