Wsconsin Abn Problems
5 replies to this topic
#1 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted August 22, 2014 - 03:52 PM
I have been working on a Wisconsin ABN that is one of my display engines, I keep running into problems with the carburetor.  Instead of getting gas to the engine the gas keeps running out of the choke, and the spark plug is always dry.  I have never had this problem with any engine before.  Btw, the float is loose and the engine has a marvel shebler carburetor. :wallbanging:  :wallbanging:  :wallbanging:
#2 Bolens 1000 ONLINE
  • 14,900 Thanks
  • 18,099 posts
Posted August 22, 2014 - 04:21 PM
If gas is running out the choke something is wrong with your needle or float.
Getting gas into the intake is another battle in itself, Hows the compression on this engine?
  • trowel said thank you
#3 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted August 22, 2014 - 04:33 PM
Compression was a little bit low, added a little bit of oil through spark plug hole as per manual, has decent compression now.
#4 Bolens 1000 ONLINE
  • 14,900 Thanks
  • 18,099 posts
Posted August 22, 2014 - 05:18 PM
Sometimes even that is not ebough if the engine has sat a long time.
The problem should correct itself after a few hours of running once full compression is built back up.
These engines should start in 1 pull if everything is mechanically sound and in good condition.
Hows the needle and seat look since its overflowing?......
#5 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,968 Thanks
  • 9,614 posts
Posted August 22, 2014 - 05:22 PM
I've had that happen on mine. I took it apart and nothing was wrong. Put it back together and it was fine. Go figure!
#6 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted August 22, 2014 - 05:27 PM
Had the bowl off before, maybe needs a little cleaning?
