Block Differences
5 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted August 20, 2014 - 10:37 PM
Are the electric ptos different between k341 blocks? The ptos I have off the masseys don't appear to have the same mounting as the John deere bock I'm using.
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted August 21, 2014 - 06:11 AM
I know there are different base/oil pan arrangements but I thought the face where the PTO mounts was the same. Are there 2 sets of mounting holes on the block?  You might also want to check the crankshaft size on the JD. They used some odd sizes on some tractors like 30mm instead of  1 or 1 1/8".
  • BairleaFarm said thank you
#3 IamSherwood OFFLINE
  • 8,391 Thanks
Posted August 21, 2014 - 06:21 AM
If I recall correctly, there are differences in the mounting holes, and as Brian said
on the shaft size too. I seem to remember drilling and tapping the JD block I put
in my MF1650.
  • MH81, BairleaFarm and New.Canadian.DB.Owner have said thanks
#4 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted August 21, 2014 - 06:42 AM
I've got that clutch but no holes. Shaft size is the same. I figured they would have all been the same
#5 Grumpy ONLINE
Grumpy
  • 721 Thanks
  • 617 posts
Posted August 21, 2014 - 06:57 AM
Kohler has a lot of different configurations. Some even have different taper on the flywheel.
#6 IamSherwood OFFLINE
  • 8,391 Thanks
Posted August 21, 2014 - 10:58 AM
Here is a reference guide to Kohler crankshafts.
I think it's in the manual section here too.
Attached File  crankshaft-reference.pdf   3.36MB   15 downloads
