E20 Plowing The Garden
14 replies to this topic
#1 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,467 Thanks
  • 5,625 posts
Posted August 20, 2014 - 05:08 AM
I asked a while ago if a GE tractor can pull a plow through the garden and how it would do, now I have an answer.
Tractor is an E20 with loader, was run in Low gear which is 2nd, power use meter was in the yellow zone occasionally going into the red zone. Owner Nick says load on the tractor is like when heavy moweing. He estimates run time of pulling the plow of 1-1/2hrs +/-.
Video speaks for itself.
http://www.ge-electr....php?f=16&t=392
  • olcowhand, MH81, Alc and 11 others have said thanks
#2 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted August 20, 2014 - 05:46 AM
Very impressive. How much HP is being generated when the meter goes into the red zone?
#3 KennyP ONLINE
  • 41,485 Thanks
  • 47,409 posts
Posted August 20, 2014 - 06:01 AM
That's cool! Thanks for the video!
#4 IamSherwood OFFLINE
  • 8,395 Thanks
Posted August 20, 2014 - 06:14 AM
Thanks for sharing that Doug. That is pretty impressive performance.
I can't wait to see ET3 in action.
#5 MH81 OFFLINE
  • 29,979 Thanks
Posted August 20, 2014 - 06:24 AM
Nice video. Is that an OEM lift?
#6 Sparky OFFLINE
Sparky
  • 1,298 Thanks
  • 1,892 posts
Posted August 20, 2014 - 06:36 AM
The drive motor is limited with a 105 amp breaker ..  The  nominal or intended amperage I think was intended to be well under that - maybe  60 to 80 amps loaded  .
  • olcowhand said thank you
#7 olcowhand ONLINE
  • 43,171 Thanks
  • 32,012 posts
Posted August 20, 2014 - 07:14 AM
So quiet, yet strong!  Thanks for the video!
#8 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted August 20, 2014 - 07:46 AM
Cool video, but it just sounds wrong.  (the audio, not the idea)
#9 Talntedmrgreen OFFLINE
  • 3,292 Thanks
  • 2,319 posts
Posted August 20, 2014 - 03:24 PM
Awesome!  Electric power can be quite impressive.
#10 js5020 ONLINE
js5020
  • 716 Thanks
  • 810 posts
Posted August 20, 2014 - 03:32 PM
Cutting through the sod like butter, great vid.
#11 plowboy OFFLINE
plowboy
    TRACTOROLOGIST
  • 133 Thanks
  • 229 posts
Posted August 20, 2014 - 04:41 PM
very cool video, I wonder where he was plowing......looks like the center of a cul de sac.....lol, hope the neighbors are understanding..... :watch_over_fence:
#12 propane1 ONLINE
propane1
  • 9,744 Thanks
  • 4,517 posts
Posted August 20, 2014 - 04:42 PM
That works very good.  Electric power may have different torque than a gas or diesel engine.  Transmission gearing maybe different too.  I like it.   Noel
#13 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,467 Thanks
  • 5,625 posts
Posted August 20, 2014 - 08:30 PM
I really don't know, there are no #s on the meters just different colour zones.
As Sparky said below there is a 105 circuit breaker, that would be max power.
At 105 amps, 36volts,  just when the circuit breaker is suppose to trip the motor would be developing about  5hp.
36V x 105A = 3780Watts - div by 746 = 5hp in theory.
As Sparky says 60 to 80 amps.
Nick figures 65% to 70% power is being used, he also says the breaker never tripped when pulling the plow but he has tripped the breaker pulling a double disc.
So he's probably using around +/- 3hp in the video. IMO
  • CRFarnsworth said thank you
#14 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,467 Thanks
  • 5,625 posts
Posted August 20, 2014 - 08:35 PM
That's the factory GE lift and sleeve hitch.
GE used the Peerless 2300 trans-axle with no reverse gear.
They called the gears D2 - D1 - L - LL  same as 4 - 3 - 2 - 1
  • MH81, KennyP, JDBrian and 1 other said thanks
#15 Mr Electrak OFFLINE
Mr Electrak
  • 128 Thanks
  • 78 posts
Posted August 21, 2014 - 05:59 PM
Thanks for posting Nick's video Doug !!
  • DH1 said thank you
