Little Advice From The Experts Needed Please
2 replies to this topic
#1 StefC OFFLINE
StefC
  • 127 Thanks
  • 45 posts
Posted August 18, 2014 - 09:15 AM
Hi there
I am experiencing what is probably a well known problem but as a novice on the GT's I am at a disadvantage...
The hydraulics lift on my Hinomoto C172 is acting "down".
The arms move slowly down when required but refuses to come back up. When I manually "pump" the arms it seems to build enough pressure to stay up.
The Moto is the same as the Massey 1010. Maybe, just maybe I can get a pointer of where and what to look for?
Will only be able to attend to this problem at the end of August though.
Mogster
#2 boyscout862 OFFLINE
  • 13,684 Thanks
  • 9,473 posts
Posted August 18, 2014 - 12:36 PM
I would suspect fluid level or filter constriction first. The valve then becomes suspect. Try downloading this manual   http://gardentractor...-and1020wsmpdf/  if you don't already have it. Good Luck, Rick
  • TomLGT195 said thank you
#3 StefC OFFLINE
StefC
  • 127 Thanks
  • 45 posts
Posted August 18, 2014 - 01:01 PM
Thanks Rick, much appreciated. And nope do not have the manual, this will surely help a lot
Mogster
